68 Dodge Coronet
Old Sep 9, 2013 | 08:43 PM
raycan2's Avatar
68 Dodge Coronet
Well got back from work after 2 weeks gone and straight to the car to get it going...I got her fired up and had her at 2-2500 rpms for 30 min to break the cam in like Comp cam instructs...Anyway now I need to change the oil in her and fix little things here and their....I do have a leak in my oil pan so I figure I would change the gasket again..My question is
Do I put ta gasket between the wind tray and the pan AND the wind tray and the engine? I was told by a mechanic just to use 1 gasket and gasket sealer on the rest,,,,The other thing my spark plug wire on #7 caught on fire being so close to the header...I am thinking ceramic boots.
Old Sep 9, 2013 | 09:15 PM
slade's Avatar
use greatstuff on the oil pan. no need for a gasket its the best
Old Sep 9, 2013 | 10:03 PM
Need a gasket on both sides !!!
Old Sep 9, 2013 | 10:38 PM
Silverick's Avatar
X2
Old Sep 10, 2013 | 07:40 AM
Originally Posted by Silverick
X2
X3
Old Sep 10, 2013 | 07:35 PM
70redbee's Avatar
X3
x4
Old Sep 10, 2013 | 08:14 PM
raycan2's Avatar
Hey
Originally Posted by 70redbee
x4
So what you all are saying I should have a gasket on both sides? LOL
Old Sep 10, 2013 | 10:18 PM
YES both sides This is the one I would use
http://www.ebay.com/itm/Mopar-Perfor...b47d29&vxp=mtr
Old Sep 11, 2013 | 12:52 AM
moe7404's Avatar
i remember when the oil scrapper pans was new. and we used two gaskets, per factory info. on the B / RB pans we would open up the oil gap to two times the factory opening with a screw driver. once i put one on a slant 6.
Old Sep 11, 2013 | 06:16 AM
Yep..... X2
Old Sep 11, 2013 | 10:40 AM
JayceDUSTER's Avatar
318 duster idle issues
Hey guys, sorry to jump in randomly but i can't find out how to post a new thread.
So i just rebuild my holley 4bbl and installed pertronix. My timing is all tuned in perfectly and my idle/mixture screws are good.
Problem: After about 1min of idle, the car will drop to about 4-500 RPM then slowly die off (Even if warm)
Also If i gas it mild-hard then let go, the car will have trouble picking back up and it will drop to very low rpm again and die almost instantly.
Any help please? Thanks alot. -Jayce
SteveRT
Oct 15, 2014 04:24 PM
johns5869
Sep 28, 2008 05:53 PM
1dart2nv
May 27, 2008 03:50 AM
GLASSMAN
Jan 8, 2008 01:34 PM
moparsforlife
Nov 27, 2007 01:14 PM
