78 Power Wagon no start
Guest
Posts: n/a
Just scored a sweet Power Wagon for $1k. Yeah! Now it randomly won't start. Boo! The battery is old, but when it does start it sounds likes it's cranking hard. It's an auto with a 360. It seemed like it would start fine for awhile when I pulled back hard on the column gear selector, but now not at all. Is it likely a NSS issue or a problem with the linkage in the steering column or elsewhere?
Thanks for any tips!
on
Also check the wires going to the starter and the grounds from battery to frame/block etc. Could be a voltage drop prob due to loose/corroded connections. let us know whats up.
And Welcome to the Forum.
You may need new bushing for the linkage and it probably needs to be adjusted. I'd have the starter tested. Also run a ground wire from the starter housing back to the negative post on the battery. This will help to allow power to "flow" through the starter. I had an issue with hard starts on my j10 and after running a ground wire like that, it started up much easier.
Guest
Posts: n/a
jbda
04-01-2013 10:22 AM
