78 Power Wagon no start
Old Jul 17, 2009 | 02:59 AM
Polaradude's Avatar
Also check the wires going to the starter and the grounds from battery to frame/block etc. Could be a voltage drop prob due to loose/corroded connections. let us know whats up.
And Welcome to the Forum.
Old Jul 18, 2009 | 09:50 AM
You may need new bushing for the linkage and it probably needs to be adjusted. I'd have the starter tested. Also run a ground wire from the starter housing back to the negative post on the battery. This will help to allow power to "flow" through the starter. I had an issue with hard starts on my j10 and after running a ground wire like that, it started up much easier.
77powerwagon
Dec 25, 2016 05:33 PM
mcarroll
Aug 25, 2015 02:38 PM
jbda
Apr 1, 2013 10:22 AM
Scotteey
Jul 17, 2009 08:47 PM
CAT-TECH
Jan 17, 2008 06:33 PM
