brake lights
Old May 23, 2009 | 04:53 PM
sgp7679's Avatar
Question brake lights
I just put a new brake light switch on my car and now only 1 light lights up when i apply brakes. Why would the other one not light up? it turns on when you turn night lights on.
Old May 23, 2009 | 05:12 PM
roadrun383's Avatar
Junior Member
This might be a dumb question but is the bulb good? the night lights and brake light is different filaments one could be broke and the other still work.
Old May 23, 2009 | 05:14 PM
sgp7679's Avatar
well i thought they ran off the same filament because of the same bulb, but i will check.
Old May 24, 2009 | 03:51 PM
sgp7679's Avatar
put new bulb in and still no stop
Old May 24, 2009 | 10:39 PM
scotts74birds's Avatar
Originally Posted by richinny
was the bulk you used an 1157?
it may be a bad socket or more likely, a break in the wire from the bulb to the harness.
if it is the right side bulb, look between the right side wire and the left side socket.
corroded socket is a real possibility. As an electrician I always use a product called "NOALOX" in wet applications.. For everyone else, use dialectric grease on all lamps and their sockets
Old May 24, 2009 | 11:55 PM
It could be just a bulb or the ground for that side. Did it work with the old switch?
AliceSML79
Aug 22, 2014 03:28 AM
1966charger
Apr 22, 2012 08:27 PM
Tommyandamanda21
Jul 13, 2011 05:46 PM
roadrun383
Jun 1, 2009 07:20 PM
