Buying a Jeep
Old Oct 7, 2010 | 08:47 AM
crwchf16's Avatar
Buying a Jeep
OK guys, I know it's been a while since I've been in here and that this is a MOPAR forum but...
I'm looking at buying a 1985 Jeep CJ-8 Scrambler this weekend and could use some pointers on what to look for when I check it out. Here's what I do know: A new 258 c.i. long block was installed 2 years ago and there's only 3k miles on it. Along with the engine it has a new water pump, fuel pump, alternator and carbeurator (Holley 4-bbl), clutch and pressure plate. it's also got new universals and steering box brace. The chassis itself has 97k. The guy mentioned there has been a little rust repaired with fiberglass and that is something I'll be looking at closest. The price is $5,500 firm. What do you think?
Old Oct 7, 2010 | 10:44 AM
Dana 30 front axle, amc 20 rear axle probably. See if the motor is a "jasper" motor (remanned in the USA). The 4 barrel is a bit large for a 258 unless it's the 370cfm(?) size.
You'll want to look closely at the frame as ther eare times that rust can be hiding. The bodys are known to be a little rusty due to age but there are plenty of repair panels out there along with fiberglass tubs.
It's hard to tell from that pic but I don't think it's worth $5500. I'd start at maybe $3000-$3500 depending on how it runs, drives and stops.
Old Oct 9, 2010 | 05:55 AM
Sangetsu's Avatar
The scrambler is in kind of high demand among the rock crawlers because of it's longer wheel base (less likely to tumble end-over-ends like the regular Jeeps).
Strangely enough I have never owned an old Jeep, my last Jeep was a Rubicon which I bought new in 2005. I really wish I still had it.
Anyway, if it's worth $5500 to you, you should go ahead and get it. I remember passing on a '70 Hemi 'cuda because I thought it wasn't worth the $6000 the owner was asking...
Old Oct 9, 2010 | 03:09 PM
studruss's Avatar
realy check the frame rails at the transision over the rear axle thats a common rust spot. Also check the spring perches front and rear they sometimes collapse. heres a pick of mine before and after.
boyswithtoys1971
Sep 1, 2010 06:42 PM
WailingWallabee
Jul 14, 2009 03:18 AM
MotoGreg
Feb 28, 2009 12:03 PM
OregonGuy1978
Nov 9, 2008 07:55 PM
mark123
Jan 10, 2008 11:24 PM
