dakota new engine.
Old Jan 23, 2016 | 04:32 PM
red67's Avatar
dakota new engine.
Moes 2001 dakota gets a new engine. the rebuilt engine came in. its a stock 3.9 V6. i wanted to do a special engine but no time and no money. the engine is $2,700. total cost $5,000. might get done next week.
Old Jan 23, 2016 | 04:46 PM
Magoo's Avatar
Question Cost ???
Welcome -- That's a lot of money, for a 15 year old truck - Hope it's a nice one.
Old Jan 23, 2016 | 05:15 PM
red67's Avatar
i think its worth it. new trans last year. new 4.1 gears and posi in 2011. and iam only 67 so it doesnt have to last no more that 15 years.
Old Jan 23, 2016 | 05:30 PM
As long as it gets all the acc. sounds ok
Old Jan 28, 2016 | 05:32 PM
red67's Avatar
today 1-28-16 Thursday, i went to the shop. the old engine is out. i hoping Monday it will be running.
Old Jan 28, 2016 | 07:36 PM
I have a 3.9 in a 1998 van NO F WAY would I spend $2700 on it... Would junk it first and buy something with a 318..
Old Jan 29, 2016 | 12:09 PM
With the cost of buying someone else's junk and then having to fix it, I like the idea of fixing what you have. But that's me.
Old Jan 30, 2016 | 08:20 PM
360 In the Mini Van..... I'm coming over....lol
Old Feb 7, 2016 | 04:31 PM
red67's Avatar
5 days new engine 45. miles, its doing good. but at idle it has a small flat spot. will get it checked out soon.
Old Feb 7, 2016 | 07:42 PM
PCM relearn.... Wait till you get 100 mile or so on it and see how it acts? Should be good after that.....
Old Feb 7, 2016 | 08:37 PM
red67's Avatar
thanks bob. i compleatly forgot about that. 100 miles. OK
Old Feb 8, 2016 | 01:32 PM
red67's Avatar
the gear shift lever will go only into P and R. will not go into thing else. its in the shop now. but i think the shop cant get to it till tomorrow.
Old Feb 8, 2016 | 02:11 PM
they messed up the linkage?
Old Feb 9, 2016 | 11:54 AM
red67's Avatar
ok what happened was i popped it in to p before it was stopped. and bent the push rod to the park pawl. will know more tomorrow.
Old Feb 9, 2016 | 11:56 AM
True Confessions, how refreshing!
Old Feb 9, 2016 | 03:31 PM
red67's Avatar
well the tail houseing is off but the trouble is above the valve body. just for reff its a 2001 Dakota V6, O.D. trans a copy of the 904 trans.
Old Feb 9, 2016 | 03:40 PM
Of all the low down rotten things you could do.... Trying to get a new trans after an engine overhaul !!!!! I'm coming to Kansas for that burger you owe me.. And we are going to talk about your bad driving habits !!!! ..hahahahahahahah...
Old Feb 9, 2016 | 05:47 PM
red67's Avatar
OK Bob. but now iam not sure it was the way i stoped that caused this. you can come to Wichita if you want. but it will have to be lunch. as i have to many lady friends to take out for dinner. LOL.
Old Feb 9, 2016 | 07:30 PM
Hehehehehehehe.... You Dog !!!!!!!
Old Feb 14, 2016 | 10:08 PM
red67's Avatar
i found a u-tube showing that the interlock in the colunm can cause this. ill need to talk to my guy in the morning.
Old Feb 15, 2016 | 08:36 AM
I thought you got that fixed already?????
Old Feb 15, 2016 | 09:12 AM
red67's Avatar
i told the guy working on it to be sure to get other peoples car done that need the car to go to work. and the first thing he did check was the colunm lock out so that is not it. he might get it done today.
Old Feb 15, 2016 | 10:20 AM
You do need your truck. Tell that guy you need you hot rod.. How else are you going to get a hair cut and your face shaved... And meet up with all those hot mommas at McDonald's?
Dam Moe...You loosing your touch....lol
Old Mar 5, 2016 | 12:46 PM
  #24
red67's Avatar
i found the flat spot. the throttle plates was dirty. $5. of cleaner it ideles fine now. now iam going to ad a low oil pressuer buzzer. will set it at 20 lbs.
Old Mar 5, 2016 | 12:56 PM
  #25
I don't know what kind of idle air control valve your truck has but find it and cleen. It will get gumed up and not work properly. Ive had one drive me crazy utill I finally replaced it.
Old Mar 6, 2016 | 01:26 PM
  #26
red67's Avatar
i forgot about the idle air control valve. as it still has a flat spot even to trying to back fire.
Old Mar 6, 2016 | 02:15 PM
  #27
Good luck Moe ,
edit from Iowa
Old Mar 6, 2016 | 05:58 PM
  #28
Check it for a bad valve....
Old Mar 10, 2016 | 07:49 PM
  #29
red67's Avatar
just got a good used throttle body. plan is. 1. adjustable trans cable. 2. idle speed control. 3. electronicly change the throttle opening singnel to computer. 4. modd the idle air valve.
Old Mar 11, 2016 | 09:30 AM
  #30
Next your going to be telling us..... It wont run..... Moooooe !!!!
Cory Riopelle
Nov 22, 2013 12:23 PM
waggl1
Jun 18, 2013 01:42 AM
jmcarp
May 15, 2013 07:39 AM
THUMPER
Feb 15, 2012 05:21 PM
destroyerbear
Dec 29, 2011 06:33 PM
