easy job just got worse
Old Jul 27, 2012 | 01:19 PM
dodgenut7's Avatar
Was putting a new carb on today and fuel line. Should of been a quick job right? Well the little plastic grommet in the spacer poped off and went right down in the intake manifold. And of course the intake is stuck solid. I have tried a rubber mallet, and rubber mallet with wood it won't move. SOMEBODY PLEASE HELP!!!!!!!!
Old Jul 27, 2012 | 01:34 PM
What about a coat hanger to fish it out. Add some pictures of what you are talking about.
Old Jul 27, 2012 | 02:19 PM
Archer's Avatar
dn -
If it hasn't found it's way too far down a runner, a vacuum cleaner with a narrow flexible opening might work too.
Old Jul 27, 2012 | 04:54 PM
blue 68 gts's Avatar
I was thinking something along the lines of a coat hanger as well/
Did you use a ton of gasket goop on the intake mani when you put it on? Pretty much just use a big pry bar to lever it out without destroying it.
Oh, and glad to see youre still here man! Missed seeing you around
Old Jul 27, 2012 | 09:22 PM
If your trying to get the intake manifold off then yes like blue 68 gts said. A big pry bar to pop it off.
Old Jul 27, 2012 | 11:27 PM
dodgenut7's Avatar
Thanks guys for the ideas I guess its my own fault I was rushing to get it done for the Chrysler power classic show in Ohio and that damn little spacer just poped off I am pretty sure it is in the number 7 or 8 cylinder my friend said don't worry about it that thing will melt I said are you kidding me you can do that in your Ford needless to say I didn't make the show and the intake is still stuck its 2:30 in Ohio and back to the garage I go wish me luck
motorcitymopar586
Jun 7, 2013 02:03 AM
67hemidart
Feb 16, 2013 10:30 AM
lalalandmamma
Jul 31, 2012 10:00 PM
Rex 360
Jan 10, 2010 08:10 AM
