g'day all i pulled my 383 down & found .
Old May 11, 2009 | 02:44 AM
deadkelly's Avatar
cheap rebuilds aren't cheap .
i found bent push rod
bad nick on big end journal
sloppy timing chain oil pump drive worn & sloppy
dizzy shaft heaps of play
slot end of dizzy worn
got my cam doctored & springs tested , springs are 110 seat & 320 on the nose . cam is a reground purple cam 311*ad , 251/250 @ .050 & 512 in / 509 ex 107 lobe sep .
& not much crosshatch on the bores .
i bought a makita 1/4" die grinder & 2 burrs today . & also dropped the heads off to the shop $450 machine valve guide down & to suit viton seals , k line & cut seat for 2.14 / 1.81 valves . bought new roll master timing chain . today's total $710 . heaps more to go . i'll get back .
Old May 11, 2009 | 03:16 AM
Polaradude's Avatar
That's gotta hurt. keep us posted bro.
Old May 11, 2009 | 05:29 AM
Red Devil's Avatar
Little Demon
ouch, hope the rebuild goes well
Old May 11, 2009 | 10:49 AM
Crazy4Carz.Com's Avatar
Sound like you are doing it right. Now is the time to do all the little things that make small amounts of power but all add up for more performance. Smoothing the ports, working the bowl area on the heads, gasket matching, (heads, intake, carb, etc) Chamfering holes, deburring everything cleaning up rough castings in the block, etc. Just make sure everything is clean, clean, clean! work with only white towels so that you can find dirt and see that there are no metal shavings or anything that shouldn't be there. I learned the white towel thing from Ray Barton years ago. Keep us posted and post pictures of the progress.
Old May 11, 2009 | 04:56 PM
this hobby is definetly an expensive one
Old May 11, 2009 | 05:16 PM
scotts74birds's Avatar
Dont want to hijack this thread , but my oil drive came out worn on one side and not the other? Bent shaft? cam walk?
Old May 11, 2009 | 10:28 PM
deadkelly's Avatar
hahaha yeah i'll check everything
Old May 11, 2009 | 11:57 PM
deadkelly's Avatar
OK i can't k line now ? so it guides made up now . that's a extra $160 so that's $610 on heads now . i'll use the cam that i have with my 1.6 rockers that will make in .545" / ex .542" lift & with that duration @ .050" that's pretty good for now , it will get my heads working . ( I'm hoping the 2 3/4 inch carb spacer will pick up some air speed to make the larger ports & valves & cam work together ) with that 107 lobe separation , when the power comes on i should know all about it . ( i have never seen how it goes because of the timing & tuning problems )
my ute ran 13.6 @ 100 miles per hour the night be for we pulled her down .
without carb spacer .. i put that on & cut a hole in the bonnet 2 1/2 hours before we pulled her down . it definitely felt like it was pulling harder mid to top .
Old May 22, 2009 | 03:45 PM
deadkelly's Avatar
OK guy here's the latest
I'm nearly half way into the port job on the 2nd head . they look like they should flow a fair bit . more race than street .
i just ordered
msd billet dizy
main & big end bearings
arp rod bolts & main studs
Mancini molly push rods
cam button
exhaust block off valley pan
& rings
next pay day I'm ordering forged dome top custom pistons . honing the block to suit . so now i can mill & deck to achieve 10.8 :1 compression .
including shipping $777 US$ so yeah I'm throwing buckets of at it again . i still got heaps more parts to buy i'll keep yous informed
Old May 29, 2009 | 03:39 PM
deadkelly's Avatar
heads finished
the heads are quite wild now . i would say there max wedge or bigger now . hey they could go backwards for all i know but i doubt it . so to make the most of it , i 'm gonna buy a new stroker crank from 440 source / or muscle motors . a 440 stroke / b mains , a friend is giving me his ly rods to use .
if my heads crack once they get some heat into them i can always use my Indy's . & if i use my Indy's i'll change my rods & cam as well .
I'm also getting diamond forged dome tops . i'll have to do something about my 727 now , maybe a bolt in sprag & Kevlar bands & better friction & steel plates . just keep throwing buckets of at it .
Old May 30, 2009 | 04:39 AM
Sounds like you have big plans for this motor. Any pics of it yet?
Any hobby that inclues automobiles is expensive. Even a simple rebuilt and cost a decent amount of money.
Old May 30, 2009 | 04:24 PM
deadkelly's Avatar
not really big plans i just stumble across things you know while I'm doing this i may as well do that so to speak . it just never ends , oh & don't worry I'm saying no to so much . my chevy mates are always on the look out for bargains they even buy stuff just to make sure I'm broke all the time . yeah i do have photos there on photo bucket , but do you think i can get them on here or my other site .
Old May 30, 2009 | 04:28 PM
Of course you can get them on here. You just need to copy and paste the "IMG" code for that photo in a new post on here and thats it. here is a link on how to post pics from Photobucket. It should be the third post in this thread.
https://moparforums.com/forums/f62/p...pictures-2128/
Old May 30, 2009 | 04:48 PM
deadkelly's Avatar
thanks tim i'll look into soon .
Old May 30, 2009 | 11:37 PM
deadkelly's Avatar
still totally stumps me . just about to pull my hair out . my photos are on photo bucket . but when i click on upload thing it opens my computer but there not on my computer . rrrrrraaaaaaggggghhhhhhhhhhhh . i'll try latter again .:mad : just snapped must go
Old May 31, 2009 | 03:16 AM
Polaradude's Avatar
DK has gone walk about....lol. Hang in there bro.
Old May 31, 2009 | 04:11 AM
If you want dead, send them to me in an email and I'll get them on photobucket for you.
Old Jun 2, 2009 | 09:56 PM
deadkelly's Avatar
QUEENSLANDER
hey guys . its the big game tonight all the boys are here already i'll get back tomorrow .
QUEENSLAND CAN MAKE IT 4 YEARS IN A ROW TONIGHT .
Old Jun 3, 2009 | 01:55 AM
What game (sport)?
Old Jun 3, 2009 | 01:07 PM
Old Jun 3, 2009 | 01:23 PM
Polaradude's Avatar
I am gonna gamble and say it's Rugby and his team is the Maroons. If it is they pounded NSW 28-18.
Old Jun 3, 2009 | 10:30 PM
  #24
deadkelly's Avatar
hell yeah maroons
on the money grant .
rugby league
that was game 1 out of a best of three series . TOO EASY
Old Jun 4, 2009 | 02:52 AM
  #25
Polaradude's Avatar
Right on bro, gotta like the Rugger.
Old Jun 7, 2009 | 06:53 PM
  #26
deadkelly's Avatar
the bottom head is upside down & the ported one . this is at about the 10 hour mark , there was a total of 30 hours porting done .
Old Jun 8, 2009 | 02:09 PM
  #27
looks good man
Old Jun 8, 2009 | 02:39 PM
  #28
deadkelly's Avatar
Originally Posted by 67 GTX
looks good man
mate i got heaps more photos , i was at a mates house his sister put this one up but had to get back to her face book farm . fair enough i'll have another go shortly .
Old Jun 8, 2009 | 03:15 PM
  #29
deadkelly's Avatar
Last edited by deadkelly; Jun 8, 2009 at 04:01 PM. Reason: seat cutting marks right & blended left , big improvement with just blending the bowls .
Old Jun 8, 2009 | 03:21 PM
  #30
deadkelly's Avatar
Last edited by deadkelly; Jun 8, 2009 at 04:05 PM. Reason: widened .060" & raised .040" & squared up
