g'day all i pulled my 383 down & found .
Old Jun 14, 2009 | 12:03 PM
  #62
deadkelly's Avatar
yeah mate your right . the heads are down the shop now ol mate down there is evening the chamber cc out . & yes I'm using muscle motors or eagle 490 cube crank & rods , gota go cya guys
Old Jun 14, 2009 | 10:39 PM
  #64
deadkelly's Avatar
it sure can take a roller
my machinist called me today & said 86 cc average chamber . with zero deck height 4cc valve reliefs 4.290 bore x 4.250 stroke that's a close to 11:1 compression , but my pistons are about .100" down the bore & i will be using Indy ez closed chamber heads 75cc not to far down the track maybe 12 months or after i get back from Canada . it all so depends on how much bore clearance for the forgies . one bore has .004" clearance & 1 has .0045" clearance all the rest are even at .0025" . i wanted to hone to suit forged pistons but that depends . i must go i'll catch yas later
Old Jun 15, 2009 | 02:06 AM
  #65
deadkelly's Avatar
[quote=deadkelly;22081]my machinist called me today & said 86 cc average chamber . with zero deck height 4cc valve reliefs 4.290 bore x 4.250 stroke that's a close to 11:1 compression , but my pistons are about .100" down the bore & i will be using Indy ez closed chamber heads 75cc not to far down the track maybe 12 months or after i get back from Canada . it all so depends on how much bore clearance for the forgies . one bore has .004" clearance & 1 has .0045" clearance all the rest are even at .0025" . i wanted to hone to suit forged pistons but that depends . ok i spoke to him again , right now with flat tops with 4cc valve reliefs with stock deck height it'll be 9.2:1 & 10:1 with indy 75 cc chambers . i marked the gasket surface so ol mate will mill the heads to clean it up which ill bump up the compression abit . he recommending only 9.5:1 - 9.8 max with iron heads . & not really over 10.8:1 with indys . mmm my chev mates not gonna be happy . i'll leave it up to the shop dude .
Old Jun 15, 2009 | 02:29 AM
  #66
deadkelly's Avatar
well pistons i have to do a bit of homework on piston size & clearance to make the most of the bores i have ( Tim will back me up here ) I'm already at 4.2945 " which is .0045 clearance ( .040" over ) & mother mopar's thick book says .040" max recommended for 69 block . ol mate said a bit of extra clearance is OK if there's no tapper ( not good , cheaper than re sleeving ) least this way i'll get a few more years out of my block . by then the world will be over anyway hahaha . a little joke between friends .
Old Jun 22, 2009 | 12:04 PM
  #67
deadkelly's Avatar
hey hypo1 this is it .
Old Jun 22, 2009 | 12:44 PM
  #68
Polaradude's Avatar
hahaha
Old Jun 27, 2009 | 05:05 PM
  #69
hypo1's Avatar
Originally Posted by deadkelly
my mates 1974 chrysler centura 265 hemi 6 cylinder 4.3 liter drag car will have 125 shot of nos as well .
that looks like something i might own hehe
Old Jun 27, 2009 | 05:14 PM
  #70
deadkelly's Avatar
no yours is a 76
Old Jul 1, 2009 | 12:02 AM
  #71
deadkelly's Avatar
the latest
the machine shop guy called today , all finished but another $730 that's around $1500 i spent on my iron 906 heads no it's more than that . oh yeah lets flush more down the dunny . i have all so been in contact with muscle motors & there tight fit pistons are a recommended .004 clearance that works out perfict . its a extra $200 for custom .040 + pistons but ya get that . I'm just waiting on my tax check can't wait .
Old Jul 1, 2009 | 07:54 AM
  #72
when you had aluminum heads deadkelly, what compression were you running?
Old Jul 1, 2009 | 08:15 AM
  #73
HemiSilva's Avatar
Member
WOW DK, it would have been nice of your machinest to at least give you a heads up that it was going to cost more then aluminum heads... I hope they work out the way you want...
Old Jul 1, 2009 | 10:28 PM
  #74
deadkelly's Avatar
i haven't used my Indy heads yet mate . Indy ez heads with 75 cc chambers with a std deck height with flat top pistons with 4 cc valve reliefs = 10:1 ( that's 383 b +040) .
Old Jul 1, 2009 | 10:40 PM
  #75
deadkelly's Avatar
mate my Chev mate is furious , he got some Chevy heads done by the same bloke for $1600 including race port job . i think this has something to do with me porting it my self & him wanting the same money . i know that i had to pay for set up twice & cleaning twice . because i got the the valve seats ruff cut before i ported em . to be honest i was expecting $1100 .
Old Jul 2, 2009 | 01:23 AM
  #76
HemiSilva's Avatar
Member
If you are happy with it then that's all that counts
Old Jul 2, 2009 | 02:29 AM
  #77
deadkelly's Avatar
i'll keep yous informed . if I'm in the 11's i'll be happy
Old Jul 2, 2009 | 04:06 AM
  #78
HemiSilva's Avatar
Member
Well then I hope you get that 11, and yes do let us know...
Old Jul 2, 2009 | 09:20 AM
  #79
i was doing some research with aluminum heads, and i figured out that they allow you to run higher compression with the same octane
isnt the higher compression needed to get back thermol efficiency?
Old Jul 2, 2009 | 10:35 PM
  #80
deadkelly's Avatar
yeah as a general rule of thumb ya can go 1 full number higher in compression with the alloy heads . when i switch to the Indy's i'll have to do some more research because i want to thump in 200 hp of nitrous as well as a big roller cam .
Old Jul 3, 2009 | 08:20 AM
  #81
i know that a lot has to be done to the motor to put nitrous on it
do you have to do something weird to the head gaskets?
Old Jul 3, 2009 | 12:31 PM
  #82
deadkelly's Avatar
yeah when i change heads i'll use thicker gaskets .
Old Jul 10, 2009 | 10:55 PM
  #83
deadkelly's Avatar
i got my heads back .
here's some finished pics
Attached Thumbnails g'day all i pulled my 383 down & found .-11072009.jpg   g'day all i pulled my 383 down & found .-11072009-013-.jpg   g'day all i pulled my 383 down & found .-11072009-015-.jpg   g'day all i pulled my 383 down & found .-11072009-002-.jpg   g'day all i pulled my 383 down & found .-11072009-010-.jpg
Old Jul 11, 2009 | 01:54 AM
  #84
deadkelly's Avatar
the springs were a lot heaver than we thought . there around 150 lbs / 350lbs there only singles with dampers . could they be the mopar battleship springs ? that's what may have bent the stock pushrod + over revving . i'm taking the block down on monday to get sonic tested .
Old Jul 11, 2009 | 03:23 AM
  #85
Polaradude's Avatar
Ya won't have to worry about valve float..
Heads look good man.
Old Jul 11, 2009 | 05:04 AM
  #86
HemiSilva's Avatar
Member
Lookin good DK, thanks for the pics...
Old Jul 11, 2009 | 09:14 AM
  #87
deadkelly's Avatar
I've got all the cash i need to do the engine .
i'll just wait for the report back from the sonic test before i order anything . mmmm it's slowly getting there . should be a real torque machine with good power as well but my exhaust will be holding it back .
Old Jul 11, 2009 | 05:37 PM
  #89
deadkelly's Avatar
yeah fenderwall headers 2 7/8 inch primaries into to 3 1/2 in exhaust . it will all be part of the Indy heads , roller cam & nitrous package .
Old Jul 12, 2009 | 05:37 AM
  #90
HemiSilva's Avatar
Member
Maybe you said before but what ET you looking for?
