Intermittent starting problem.
Old Aug 21, 2020 | 12:18 PM
Jasman57's Avatar
My 1965 Plymouth Valiant occasionally won’t start. It doesn’t crank. The battery and starter are good. The radio comes on when you turn the key, but nothing at all happens with the engine. It has happened three times in three months. Each time the car eventually started and it would be weeks before it happened again. Any ideas what might be wrong?
Old Aug 22, 2020 | 05:37 AM
Welcome.
Bad connections or start relay.
Old Aug 22, 2020 | 06:19 AM
Jasman57's Avatar
I’ve worked pretty hard on checking/fixing possible problem wires but have not done anything with start relay. Thanks.
Old Aug 22, 2020 | 11:28 AM
relay had me baffled as well on an old ramcharger i had. it's a good place to check out.
Old Aug 22, 2020 | 02:39 PM
Jasman57's Avatar
Getting a new relay tomorrow morning. Thing that had me confused was the intermittent part. I wasn’t aware a relay could be failing without being totally broken. I guess we’ll see.
Old Aug 22, 2020 | 06:44 PM
Check the Neutral safety switch and or Clutch switch.
Old Aug 22, 2020 | 07:11 PM
Jasman57's Avatar
Check.
Old Aug 22, 2020 | 07:17 PM
Not saying its not the start relay... Just a few other things to check on these old gals...
Old Aug 22, 2020 | 08:00 PM
Jasman57's Avatar
What I was wondering, though, is if the clutch safety switch was broken, wouldn’t the car fail to start every time? The not starting problem has happened intermittently.
Old Aug 23, 2020 | 06:03 AM
More like the switch hanging up intermittently.... That was my thoughts..
Old Aug 23, 2020 | 06:29 AM
Jasman57's Avatar
Well, I bypassed the clutch switch and replaced starter relay. Will see how that goes. Thanks for your thoughts.
Old Aug 23, 2020 | 03:21 PM
Keep us posted...
hkestes
Sep 7, 2018 08:51 PM
1970DusterUSMC340
Jan 12, 2018 01:07 PM
Panderz
Jun 30, 2016 11:42 AM
barry440
Jul 3, 2012 02:49 PM
63valiant
May 21, 2012 11:26 AM
