Jack problems
Old 05-26-2010 | 09:35 PM
RROriginals's Avatar
Jack problems
Well, I found out I can't have the car in my GF's driveway, but my driveway is mostly compacted dirt and stuff like that, would I be able to jack up the car without any problems? The ground is 99% level and very hard to dig up.
Old 05-26-2010 | 10:04 PM
pjjaramillo's Avatar
As long as the dirt is hard/compacted and flat where you place the jack, it should be alright. If it is soft or has divots in it, that is not a good spot to raise your car. Oh, and try not to get too much dirt on your jack.
Old 05-26-2010 | 10:16 PM
1966sportfury's Avatar
A.K.A Bob Dodge
level it out so a peice of plywood can lay flat 8"x8" or so, or just a piece of 2x6
Old 05-27-2010 | 03:38 AM
When I was parting out my J10 last year, I was on dirt. A 2'x2' piece of 3/4" plywood worked great under the jack. Whatever you do, do not jack it up or have it sitting on a jackstand on the dirt.
Old 05-27-2010 | 04:11 AM
Thanks guys, I was going to put a piece of plywood under it, level it all out, roll the car on it and then jack it up, it's for my brake job so eeeh... I don't know how this will work.
Old 05-27-2010 | 04:19 AM
Polaradude's Avatar
Just get some jack stands and chock your rear wheels.
Old 05-27-2010 | 04:44 AM
Use the plywood and make sure you use stands also.... This will work out fine.....
Old 05-27-2010 | 05:44 AM
Sgt. Veteran's Avatar
Old As Dirt
Be careful man flat people make bad mechanics, plywood and stands like everyone says
Old 05-27-2010 | 09:45 AM
67gtxclone's Avatar
Please be safe and use jack stands as well. You will want plywood under those too.
Old 05-27-2010 | 04:37 PM
Crazy4Carz.Com's Avatar
Oh well one less person posting here. Jack up your car on dirt and you will be dead soon. Even blacktop in the summer or on a warm day is too soft to jack a car on. Plywood is better but if the dirt goes away the plywood will shift and down will come the car!
Old 05-27-2010 | 04:47 PM
My driver isn't doing my brakes, my friend's dad is doing it, he owns his own shop, I had 2 Ton jack stands and a 2 ton service jack, he got me 6 ton stands and a 6 ton service lol. Overkill? Most definitely.
Hopefully this all goes well, I tested the area I'm putting it on, I have a 1 ton steel beam sitting on the side of my house so I used a lift and put it on, held up pretty darn well!, Even added 500lbs and it didn't budge.
Old 05-28-2010 | 05:46 AM
1500 pounds is probably not enough to imitate the front end.
like everyone else said, be careful.
Old 05-28-2010 | 06:32 AM
A.K.A Bob Dodge
1 ton = 2000 lbs, so 2500. i do it all the time too. well a short ton is 2000 lbs an a long ton is 2240... short ton, long ton what a crock
Old 05-28-2010 | 09:03 PM
I just got the car in at 3:15, it's in my yard now, I ended up jacking up one side of it and it held up well, about 5" off the ground first run. Excited about this one.
xvodysseusvx
06-25-2018 05:38 PM
robin henkel
08-24-2011 01:41 PM
67440X
04-01-2011 04:21 PM
mach3107
02-09-2011 12:10 PM
puffbunny
02-05-2007 11:54 AM
