Oil pan pickup problem again
Old Feb 20, 2013 | 07:56 PM
PURPLE HORONET's Avatar
I have a Mopar performance 8qt pan p5007816. I just got my oil pickup in today Mopar Performance p5007817. The pickup is wrong it hits my rods.. Did somebody swap out the pickups in the box. Or did I order the wrong item.
Here are two pics, what does the 8qt 3/8 thread pickup look like. I know the half is the square one.
Attached Thumbnails Oil pan pickup problem again-312-p5007817.jpg   Oil pan pickup problem again-312-p5007818.jpg
Old Feb 20, 2013 | 09:23 PM
It should look like number two.
Old Feb 20, 2013 | 10:52 PM
The one I got looks like #2, jegs and a couple other sites show a pic of the round looking factory one being a 3/8 thread 8qt pickup. Am I missing something, I am screwing it in the block were the stock one came out. This has really became a pain in the rear, I thought by useing Mopar Performance parts I would be cutting out the BS of fabbing and head scratching.
Old Feb 20, 2013 | 11:02 PM
Is the pick up parallel with the block ? Can you bend it a little ? Is it a stroker motor ? any pictures ?
Old Feb 20, 2013 | 11:11 PM
Stock stroke the tray fits fine, give me 10 min I will get you a pic.
Old Feb 20, 2013 | 11:27 PM
The factory windage tray clears fine
Attached Thumbnails Oil pan pickup problem again-pic3.jpg   Oil pan pickup problem again-pic1.jpg   Oil pan pickup problem again-pic2.jpg
Old Feb 21, 2013 | 04:36 AM
bigblock's Avatar
Thats way more than a little bit,aint it! So if you bend it out of the way...Will the pan still fit? Or is the pickup just wrong?
Old Feb 21, 2013 | 09:07 AM
Its just not correct, if I bend it to clear,, the oil pickup end will be so out of wack. Whats weird, the dept its correct with thee oil pan dept
Old Feb 21, 2013 | 01:04 PM
I would have to say it is bent wrong from the factory
Old Feb 21, 2013 | 03:24 PM
Talked to a guy that builds a lot of race mopars and he said that was the correct part number. Also called Mancini and they said the same thing. So I ordered another one from Mancini. I guses in a few days we will see what happens.
Old Feb 21, 2013 | 06:56 PM
The problem with Mopar Performance parts these days is that they can even be made in China.
Old Feb 22, 2013 | 12:31 PM
Yah sad to say, The guy local I talked to that builds a lot of Mopars for the strip had told me he does not use their stuff anymore. He had said their stuff was made poorly now. Years ago when I messed with a lot of Mopars their stuff was top notch. Im not a big GM fan but their crate engine stuff is awesome, that zz502 and 572 are bad a$$.
Old Feb 22, 2013 | 02:53 PM
pro-tech's Avatar
Mopar crate motors are also kick A--.. And Mike at mrlperformance.com builds whatever you want and is always willing to answer any performance question you may have. He is also on the sister site of this forum. Mopar & muscle car tech forums
Old Feb 22, 2013 | 06:54 PM
Gorts 5th's Avatar
Smile
seems like the only thing our country manufactures today is over weight people.
And weapons!
Old Feb 23, 2013 | 05:15 AM
pro-tech's Avatar
I hear that. Everywhere you look it is made in China. They own this country. Its called outsourcing.. I call it Bullsh-t.
Old Feb 23, 2013 | 05:17 AM
Gorts 5th's Avatar
Exclamation
boy that's for sure what a bunch of azz holes they did this ***** for there own gain!
Old Feb 23, 2013 | 05:21 AM
pro-tech's Avatar
Its Obama care.
Old Feb 23, 2013 | 05:25 AM
Gorts 5th's Avatar
Exclamation
i keep hearing the rumors... Civil war.
Old Feb 24, 2013 | 12:52 PM
pro-tech's Avatar
The defense dept asked the generals if they would have a problem with shooting american citizens if they said yes they were let go. I cant remember where I read or heard that. But I kinda believe it with all the BS over gun control.
Old Feb 25, 2013 | 10:03 PM
Got another Mopar Performance pickup in from Mancini, it still was not correct but closer. It was 1 1/2 inches off the bottom of the pan and still hit the tray. I did get it bent correct and got it to work after taking it on and off about 10 times.. I will never buy another Mopar Performance pan or pickup again. JUNK..
Before pic before I altered it.
Old Feb 25, 2013 | 10:18 PM
Was it actually 1 1/2" off the bottom ??? IT should be about 3/8" I wonder if a short extension from pluming dept would work
Old Feb 26, 2013 | 11:58 AM
Yah 1.5 off the bottom and it still hit the rods, I got it all worked out, took some of the bend out of it. It just pissed me off buying the correct pan and pickup and they do not fit correct. If I have not been farting around with this pickup problem for 3 weeks I would have sent all of it back and got a Milodon set up.
PURPLE HORONET
Feb 12, 2013 06:23 PM
Mr.4spd
Oct 28, 2012 04:12 PM
OHD
Apr 7, 2010 09:27 AM
MarkyMark12345
Apr 10, 2009 06:43 PM
dzltd02
Oct 28, 2008 08:25 AM
