spark problem
Old Dec 31, 2010 | 01:58 PM
ibhammer's Avatar
spark problem
i am having a problem with my 73 challenger shuting off after 15-20 minutes of running any ideas ?
Old Dec 31, 2010 | 08:18 PM
what do you mean by shutting off?
does the car sputter, then die?
sounds like ignition to me
could it be the ignition box: when the car gets hot, it stops working.
when the car cools down after a while, does it start back up?
Old Jan 1, 2011 | 12:54 AM
blue 68 gts's Avatar
It's hard to diagnoise a problem with a car when there is hardly any information..
My diagnoisis to the information you gave would be vapor lock;
But it could be any amount of any other things. More info is needed..
Old Jan 1, 2011 | 05:21 AM
rdrunner1974's Avatar
Spark problem
Yep, more info needed. How do you know it's a SPARK problem, what have you done to trouble shoot?
Will it restart after it shuts down? Could be the ECU or ballast resister. You can put a jumper wire accrost the ballast and see if it restarts. The ECU needs to be WELL grounded to the firewall.
Take the coil wire out of the dist. and hold it 1/2inch from a ground (not thr carb) and see if you have spark when the problem occurs.
Justin Ward
Sep 3, 2021 10:38 AM
buttton
Apr 1, 2013 10:00 AM
austin
Sep 18, 2012 12:37 PM
deadkelly
Aug 26, 2011 02:06 PM
Pfhoenix
Apr 3, 2008 10:44 PM
