torque converter
Old Dec 13, 2009 | 04:49 AM
67Polara's Avatar
torque converter
oook... so i got a new motor for my Polara,i got theold one out no problem, but, i tried to put the new one in and the trans and the engine wont line up. i've come to the comclusion that it is the torque converter.
the repair manualsays it should be sitting backin the bellhousing 1/2 of an inch but i can only get it in 1/4 of an inch.
any suggests?
Old Dec 13, 2009 | 06:36 AM
You do not have it seated in far enough. Keep rotating it while pushing up.
Basically place the palm of your right hand in the 4-5 o'clock position and rotate it counter clockwise. At the same time, with the same hend, give the torque convertor an upward push. This will help to seat the torque convertor on the input shaft of the tranny.
Old Dec 13, 2009 | 09:40 PM
blue 68 gts's Avatar
Yep.. what Tim said..
Just need to keep spinning..
Old Dec 19, 2009 | 10:13 PM
67Polara's Avatar
yupp yupp,it worked,only other problem was the flex plate ddnt fix =/
Old Dec 19, 2009 | 10:23 PM
scotts74birds's Avatar
Old Dec 20, 2009 | 02:56 AM
BuckNeccid's Avatar
There are two sizes of flex plates, and the flex plate has one hole that is not symetrical to the other three. By having that one hole off just a little from the others, it makes the torque convertor line up in only one way, keeping the balance where it needs to be. I THINK the externally balanced convertors changed that, and they are all symetrical holes. Anyone sure on that one?
If the holes line up too short or too long, then you need the other size flex plate.
Old Dec 20, 2009 | 03:44 AM
What BuckNeccid said and also the bolt holes will line up only one way. On our race cars we put the first bolt in loose and then turn the engine over and try the second bolt. It usually fits and the third is the real test... If it fits then go on to the fourth. When all are in finger tight go back to number one remove it and locktite it and tighten to spects... Then take a spray bomb and spray a small amount of paint on one of the bolts and flexplate. Next time just rotate the converter to the paint and then install the bolts right the first time....
Old May 29, 2012 | 04:54 PM
weston's Avatar
so i have about the same problem as this guy but i have a 1961 polara i'm trying to put a 383 in but i'm having trouble IDing the tranny and finding a torque converter... can anyone help?
Old Jul 28, 2012 | 01:49 PM
Phils66dodgecoronet's Avatar
Motor turnover question
When trying to start my car the motor doesn't want to turn over and sucks a lot of juice and the starter gets hot but the car don't start...I loose all lighting in the dash and I just put new big wires on it.... when I unbolt the flex plate from the torque converter the starter spins the torque converter freely and didn't really get warm...what might be the problem...I have a 66 dodge coronet 440 plz help!!!!!!!!!!!!
74cuda
Cuda Specific Discussion
Sep 8, 2017 04:08 PM
Minnesota Guy
Oct 21, 2010 10:41 AM
Nomadci
Aug 23, 2010 02:50 AM
smackhonda
May 26, 2010 07:17 PM
68 gtx
Oct 16, 2009 03:43 PM
