Towing capacity 727 tranny
Old Nov 1, 2010 | 12:59 PM
auerdoan's Avatar
I have a set up on my 59 ford f-250
with a '76 440 and a tranny a727b with these numbers 6A162543.
the rear axle is from what i believe is a 69 ford
im curious what a safe bet of towing capacity would be.
the truck weight on pink slip show 3500 im thinking that was estimated with all 59 ford parts
thank in advance for your help
Old Nov 2, 2010 | 03:00 AM
It all depends on how built up the transmission is. In stock condition, you can tow a car trailer with a truck on it, 26'-32' camper, etc. I would think your truck would limit you more than your transmission.
What do you want to tow?
Old Nov 11, 2010 | 12:15 PM
auerdoan's Avatar
i have my eye on a 68 air stream a friend of mine has
im not sure of the length
but i looked up the possibilities.
from 17' to 30'
and the weight from 2300 to 4600
hitch weight from 270 to 403
im sure the little pop campers would no problem
thanks for your help and ideas!
Auerdoan
Old Nov 12, 2010 | 03:28 AM
A stock 727 will be able to handle that camper no problem. The only thing that I would do is add in a tranny cooler infront of the radiator for added cooling. Heat is the #1 cause for trannies failing.
Old Nov 18, 2010 | 12:00 PM
auerdoan's Avatar
thanks for your reply. im curious what the operating temperature of the tranny fluid ideally should be in these 727s.
Old Nov 19, 2010 | 02:57 AM
175*F-200*F is normal. you don't want less than 150 as it will cause your transmission to not operate properly. If you are hitting over 225*F, then you will need a larger cooler. 275*F is the max if you are towing up a steep upgrade but only recommended for a short time.
I would install an inline or tranny pan temperature sensor and run a medium size cooler. that will probably be more than enough.
Old Nov 19, 2010 | 11:17 PM
auerdoan's Avatar
I appreciate your help and suggestions!
i got lucky on this one the guy who tore up this old Ford new what he was doing.
theres a tranny cooler in front of my radiator
i would of left the truck as is .. but after looking it over driving it with a 440 man its tough to change something thats working..
im looking forward using it for all its practical means and than some.
Old Nov 20, 2010 | 04:44 AM
If the guy built it right, then I would leave it alone and see what it does. You can always upgrade what you need later.
richard669
Nov 3, 2012 11:19 PM
samuelcosmo76
Aug 27, 2012 08:20 PM
michuy
Jul 1, 2012 01:31 AM
a.johansson84
Mar 27, 2012 05:07 AM
johnthegoalie
Feb 19, 2009 12:29 AM
