Valve Timing Video.
Old Dec 27, 2011 | 10:10 AM
Valve Timing Video.
http://www.youtube.com/watch?v=qxKEx...eature=related
Old Dec 27, 2011 | 11:23 AM
Cool Video..thanks for posting
Old Dec 27, 2011 | 02:27 PM
scotty's Avatar
so what would the specs be if the motors been altered????how do you know your timing is perfect?trial n error?
Old Dec 27, 2011 | 04:00 PM
This is the best learning tool I've found in awhile. If by altered you mean camshaft change, the specs would be different to each cam, like shown at the end of the video. Timing the cam would be done with a degree wheel to advance or retard it slightly to change the power curve RPM range. There are many tutorials about this on U-Tube that would explain it better than I could. That spiral graphic can be related to cam manufacturers lingo of Intake open BTDC, close ABDC etc. and takes a little mystery out of reading a cam card.
Old Dec 27, 2011 | 06:20 PM
blue 68 gts's Avatar
Use a cam degree wheel to get the "perfect timing".
Then you can use an off set cam bushing or crank key ways to change the cam degree to either advance to retard (depending on if you want more torque or hp)
19newport72
Mar 27, 2024 06:44 PM
74Runneer
Oct 17, 2015 10:32 AM
Gorts 5th
Dec 19, 2012 04:52 PM
a.johansson84
May 27, 2012 03:30 AM
Manoharvalves
Sep 15, 2011 10:53 PM
