74 hornet 440 727
Old Oct 30, 2010 | 12:53 PM
hornetnut's Avatar
74 hornet 440 727
I've recently realized that making my car fast without the huge price tag is gonna take more than i can get out of my amc motor, so my buddy traded me a 67 440, .030, flat tops and forged, steel crank, the block was standard as it wasn't the block that was used for this rotating assembly, its balanced and only had 4 races on it, so i just got the block back from the machine shop and it looks great!! I made a deal for a set of eddy heads from another guy with a set of crane rockers, i've got a 582 ultradyne solid, m1 manifold, 727 trans with reverse pattern manual valve body, 3500 converter..
I have to make a set of headers, using a front plate setup, still have to tie the frame together, and finish the cage
Old Nov 1, 2010 | 03:29 AM
This will be a cool build!
Old Nov 1, 2010 | 02:29 PM
2x on that
Old Nov 1, 2010 | 08:17 PM
hornetnut's Avatar
i knew that the stock rear end wouldnt hold up so when i first got the car 11 years ago, i put a 9 inch ford in it, its got 4.11's and a spool right now... i'm gonna leave the leaf springs in it for now because its setup like super stock springs and i have yet to have traction problems... i'd like to see how far i can get with this setup...
what do you guys think for a carb? i'm thinking that i should start with a 850 dp holley, and tune from there.. my current 700 dp i dont believe will be enough..
Old Nov 2, 2010 | 01:57 PM
an 850 would probably be better, but you can get away with the 700 for now
Old Nov 3, 2010 | 01:22 AM
dusterboy89's Avatar
my dad and me are big amc fans got a 77 hornet hatchback and amx hortnet hatchback and a gremlin
Attached Thumbnails 74 hornet 440 727-30066_113238215386650_100001014155429_81299_2220670_n.jpg
Old Nov 3, 2010 | 01:24 AM
goodluck with your build
Old Nov 3, 2010 | 04:59 AM
62Furious's Avatar
nice ride sounds like you will put down some numbers when it is finished,let us know how the build goes
Old Nov 3, 2010 | 12:11 PM
hornetnut's Avatar
i'll post pics as it goes along, theres been no progress as i'm moving right now so spare time is null...
Old Nov 6, 2010 | 06:07 PM
challenger's Avatar
keep us informed
Old Nov 17, 2010 | 06:56 PM
hornetnut's Avatar
finally had some time to start assembly on the motor, cranks in, pistons and rods are in, going on thursday to assemble the heads and install those too..
Old Nov 19, 2010 | 11:21 PM
hornetnut's Avatar
http://i241.photobucket.com/albums/f...g?t=1290237561
Old Nov 19, 2010 | 11:41 PM
Silverick's Avatar
Sweeet!
Old Nov 19, 2010 | 11:53 PM
hornetnut's Avatar
my day started off bumpy... literally......, got hit by a guy who ran a red light on my way to work, later went to finish assembly on the 440 and the intake wont fit, the rocker shafts are wrong so everything came to a halt till i can figure out what to do... the intake is what i was told is a "stage 6", which is why it wont fit my heads..the rocker shafts wont fit through my crane gold rockers, ohh well, will start fresh tomm...
Old Nov 20, 2010 | 04:52 AM
Very nice!
Sorry to hear about your day. There will be better ones.
Old Nov 20, 2010 | 05:03 AM
For those who are not click happy
100_2610.jpg?t=1290237561
pipdog69
Mar 13, 2012 11:01 PM
samuelcosmo76
Jan 12, 2011 03:27 AM
Seawolf
Oct 15, 2009 04:07 PM
jd.fisher
Mar 25, 2009 06:08 PM
johanovich
Mar 14, 2009 02:11 PM
