1971 Leaky Challenger
Old Aug 25, 2013 | 06:10 AM
dfrazz's Avatar
First time post, long time reader - I have a '71 Challenger with a 360 crate engine and am needing to change the oil pan gasket. The oil pan appears to be blocked by the torsion bar, but I was wondering if anyone has dropped an oil pan on a 360 engine without having to remove the torsion bar.
Also, there is a ticking on the right side of the engine. I'm guessing this is a header gasket leak but wanted to ask and advice on what this could be?
Thanks for your help.
Old Aug 25, 2013 | 08:35 AM
HemiMeech's Avatar
Personally, I find it much easier to pull the motor --Might be a hop in the *** for some, but I like to work with things at waist level because of lining up everything for the pan and rear gasket.
Meech
Old Aug 25, 2013 | 12:27 PM
Terminology The bar that goes under the oil pan I would call a drag link. Just need to take it loose and the motor mounts loose and raise the motor up Then you can wiggle the pan out .. You may need to rotate the crank for clearance
Ckurish1367
Aug 28, 2012 09:02 AM
DartSwinger
Jul 31, 2012 10:02 PM
patsquatch
Jul 26, 2012 02:29 AM
Mr. Belvedere II
Jun 21, 2012 08:50 AM
mahd
Sep 13, 2008 04:30 AM
