360 First Start
Old Sep 30, 2010 | 03:25 PM
wingnutt2420's Avatar
360 Mopar
360 First Start
Hey guys I was wondering if there is a speciel way to start and brake in my rebuilt 360?
Old Sep 30, 2010 | 04:03 PM
well did you replace the cam and lifters?
if yes, you used molly lube right?
the motor has to run at around 2000 rpm for 20 minutes
then shut the motor off and drain the oil(let the car cool for a bit)
Old Sep 30, 2010 | 04:35 PM
360 Mopar
Is it really that simple? We completely rebuilt it. Cam crank rods bearings pistons etc.
Old Sep 30, 2010 | 07:43 PM
1966sportfury's Avatar
A.K.A Bob Dodge
the 2000 rpm is the recomended way, i just start them at let them idle as normal, and never had a problem with cam break in, shut it down 20 30 minutes after, let it cool then drain the oil, re torque the exaust manifold bolts, intake, water pump, head bolts if you dont use perma torque type gasgets. then i drive them esay for around 800~1000 miles then give them hell, everyone has their own way, if it works for them then it all good.
edit: where at in washington are you?
Old Oct 1, 2010 | 02:34 AM
After you drain the oil....... don't forget to put new oil in along with a new filter.
Old Oct 1, 2010 | 09:47 AM
360 Mopar
I'm a big believer in synthetic motor oil. Can you break it in with conventional oil and then put in synthetic?
Old Oct 1, 2010 | 09:58 AM
I know for a fact that the FJS (full size jeep i.e. j10, Grand Wagoneer, etc) community uses diesel oil in their motors after rebuilding them because of the amount of zinc. Doesn't effect those motors at all.
Old Oct 2, 2010 | 06:45 PM
yes
the break in is the most important part
after that, do whatever you normally do
jbda
Apr 1, 2013 10:22 AM
PuppetMaster
Jun 3, 2010 05:47 PM
sgp7679
May 25, 2009 02:35 AM
Cudafever
Feb 4, 2009 09:36 AM
