440 questions..
Old Dec 20, 2009 | 09:40 AM
theomahamoparguy's Avatar
same deck but everything else is different. heads, waterpump etc. I think the block is useable though, just gotta convert stuff over to it. So you got a block, crank and rods actually. youll have to get everything else. Its probably a 413.
Old Dec 20, 2009 | 09:41 AM
when you say old, how old do you mean?
Old Dec 20, 2009 | 09:43 AM
(some industrial motors were similar to the regular ones in the late '70's)
Old Dec 20, 2009 | 09:49 AM
well like I said, it depends what year the industrial is, If it looks like it has the "normal" big-block heads, your ok. If it has those "special" industrial heads and associated parts, then it will take some work and money. BTW, you will know right away when you see the old industrial 413 of the '60's. It looks totally different than a normal 440-413. The newer industrial looks similar to the regular big-blocks.
So basically, you gotta figure out whaat you have.
Old Dec 20, 2009 | 09:52 AM
mid '70's, I think you should be ok. Send picture of RV motor.
Old Dec 20, 2009 | 09:53 AM
yes it would look similar to 400 motor
Old Dec 20, 2009 | 09:55 AM
hey, I gotta go now. Keep me posted. I'll check back in a while.
Old Dec 20, 2009 | 02:33 PM
post a pic of the motor
MoparMan76
Jan 14, 2011 01:31 PM
tice
Aug 13, 2009 06:35 PM
69coronetkyle
Aug 4, 2009 02:22 PM
kisshippie13
May 23, 2009 12:47 PM
piratemike
Mar 20, 2009 02:36 AM
