65 Polara Power Steering Pump Identification
ok, so Rock Auto has the parts...but 5 or 6 options
...no option to speak to a tech ...
& i have a leaking pump (1/16" end play & 1/32+ lateral play on bearing/bushing) which i am going to tear down & rebuild myself
i need to order the correct kit...for my pump cast with ....TRW, 14, I6N & the reservoir is stamped with a circular logo, letters AMC
it has a hex end shaft & a circular filler neck,
Will someone kindly guide me to buying the correct seal rebuild kit ?
gates 350380, which contains the same parts as your recommendation...& then some, such as the bushing. Better to have it available on hand than to find out its needed but would require another order.
lexi from rock auto replied my email...short but sweet enough. she reaffirmed they do not have parts look up...but also stated, if info beyond their listing is sought, its not necessary as not provided by the seal kit manufacturer...
in other words, figure it out without their input or leave us alone...ha ha ha
Your welcome..... I didnt check but you might also see if Edelman/Parker mite have something for that unit.... Anyway... Keep us posted on how the rebuild go's.. Best of luck... Cheers
Brace21
Dec 4, 2017 05:32 PM
heminate
Aug 17, 2009 08:07 PM
