65 Polara Power Steering Pump Identification
Old Nov 23, 2018 | 07:56 AM
65PolaraE-1's Avatar
ok, so Rock Auto has the parts...but 5 or 6 options
...no option to speak to a tech ...
& i have a leaking pump (1/16" end play & 1/32+ lateral play on bearing/bushing) which i am going to tear down & rebuild myself
i need to order the correct kit...for my pump cast with ....TRW, 14, I6N & the reservoir is stamped with a circular logo, letters AMC
it has a hex end shaft & a circular filler neck,
Will someone kindly guide me to buying the correct seal rebuild kit ?
Old Nov 23, 2018 | 07:58 AM
if it makes a difference, original engine is a B-383
Old Nov 23, 2018 | 10:38 AM
Have a look at the Gates Power steering kit. Part number 351400.... Dont know where to get any hard parts if you need them..... Rebuilder maybe... Just my 2 cents...
Old Nov 23, 2018 | 11:22 AM
thanks racer hog
Old Nov 24, 2018 | 04:44 PM
gates 350380, which contains the same parts as your recommendation...& then some, such as the bushing. Better to have it available on hand than to find out its needed but would require another order.
lexi from rock auto replied my email...short but sweet enough. she reaffirmed they do not have parts look up...but also stated, if info beyond their listing is sought, its not necessary as not provided by the seal kit manufacturer...
in other words, figure it out without their input or leave us alone...ha ha ha
Old Nov 24, 2018 | 06:06 PM
Your welcome..... I didnt check but you might also see if Edelman/Parker mite have something for that unit.... Anyway... Keep us posted on how the rebuild go's.. Best of luck... Cheers
Brace21
Dec 4, 2017 05:32 PM
labradorian70
Oct 11, 2014 05:10 PM
66Newport
Apr 22, 2013 04:43 PM
1968polara383
Jan 8, 2012 07:45 AM
heminate
Aug 17, 2009 08:07 PM
