69 440 questions
Old Jan 7, 2011 | 05:01 PM
dodge6x6x6's Avatar
69 440 questions
I have a (near as I can tell) 1969 440 BB with a steel crank drilled for a manual tranny heads and a factory cast intake man. How can I tell what I really have? and what it is worth? and would any body want it?
Old Jan 7, 2011 | 06:30 PM
1966sportfury's Avatar
A.K.A Bob Dodge
casting numbers on the side of the block, post them.
Old Jan 7, 2011 | 10:52 PM
Some cranks can be "hard to tell" Some were drilled a little undersize and a little shallow. You used to be able to buy undersize pilot bushings, and guys used to cut, say, 3/8" or so off the gearbox shaft so the shaft would not bottom
There's no way that I know of to tell from a casting no. whether it's a stick or auto engine. If it's complete, look for kickdown brackets/ linkage on the intake/ carb
Old Jan 8, 2011 | 07:41 AM
post up some pics
Old Jan 8, 2011 | 05:08 PM
dodge6x6x6's Avatar
casting number on the heads is 2843906-6 the crank piolt bushing hole is about 1 1/4" deep I also found the bell hsg for it, and the casting number on the block is 2536430-3 and the intake has a date in cast of 1-24-69 and number of 2806178
Old Jan 8, 2011 | 05:19 PM
dodge6x6x6's Avatar
Trying to figure out how to post picts???
Old Jan 8, 2011 | 05:51 PM
Hick727's Avatar
Tinypic.com
Old Jan 8, 2011 | 08:10 PM
make an account with photobucket (its free)
upload the pics to their, and copy the IMG code (i think) and just post that here
Old Jan 9, 2011 | 10:11 AM
dodge6x6x6's Avatar
Old Jan 9, 2011 | 10:12 AM
dodge6x6x6's Avatar
Old Jan 13, 2011 | 01:57 PM
not completely sure on the price
the block probably needs machine work, along with the heads
if the heads need to be milled, then so does the intake
3-6 hundred sounds around the zone to me
MoparMan76
Jan 14, 2011 01:31 PM
tice
Aug 13, 2009 06:35 PM
69coronetkyle
Aug 4, 2009 02:22 PM
kisshippie13
May 23, 2009 12:47 PM
piratemike
Mar 20, 2009 02:36 AM
