84 D100 225 Slant Six problems
Old Oct 5, 2010 | 03:31 PM
cmetzbower's Avatar
Hey, I have a 84 225 Slant Six with the stock one bbl carb. The engine will run ok for about 2mins and then wont idle unless I'm feeding it fuel OR it will idle ok but it has zero power and when I start to give it gas it starts to rev up but the quickly acts like its going to bog down an die (when it does that it won't run unless i have the air cleaner on and tightened down). I've replaced the fuel pump, fuel filter, fuel lines (about a year ago), pcv valve, pcv filter canister, and rebuilt the carb about a year ago. the vacuum pump is working correctly (i tested that from a line coming off the carb). Any help would be most appreciated. by the way the replacements or rebuilds were because of this problem and because the thing get 8-12mpg.
Old Oct 5, 2010 | 07:10 PM
1966sportfury's Avatar
A.K.A Bob Dodge
have you checked for vacuum leaks?
Old Oct 6, 2010 | 02:32 AM
X2 on the vacuum leak. Have you given it a tune up as well?
Old Oct 6, 2010 | 12:00 PM
Minnesota Guy's Avatar
Did it do this before you rebuilt the carb? "1 year ago"?..How many miles on the motor?
Old Oct 7, 2010 | 08:24 AM
cmetzbower's Avatar
It has over 120,000mi on it and it was doing it before the carb rebuild. I haven't driven it much after rebuilding the carb since I was away in the military but it was having the same prob before the fuel filter replacement.
Old Oct 7, 2010 | 10:45 AM
Inspect all the vacuum lines. Any cracks, even the smallest ones, replace the line.
Old Oct 7, 2010 | 02:35 PM
cmetzbower's Avatar
I've been looking for leaks and cracked vacuum line and so far haven't found anything. Any idea's? maybe a leak between cylinders? it also seems to blow oil into the air cleaner.
Old Oct 8, 2010 | 02:56 AM
Are you sure that you have teh right PCV valve?
Alos, if you are blowing oil into the air filter, you may have blow-by around a piston ring or valve. What does the compression look like across all of the cylinders?
Old Oct 8, 2010 | 03:24 AM
Polaradude's Avatar
Leak down test is your friend.
Old Oct 11, 2010 | 12:27 AM
cmetzbower's Avatar
ok, compression is normal not great but enough. I'm about to just rebuild the entire engine.
1974moparduster
Oct 2, 2013 06:02 PM
kyle74
15
Jan 11, 2013 03:26 AM
1966DartConvertible
Aug 6, 2010 09:03 AM
hatboy2002
Jun 18, 2008 10:05 AM
