b-body ignition removal
Old Nov 6, 2012 | 06:28 AM
castillo70's Avatar
i have a new keyed ignition i would like to swap out for the old ratty one.how do i remove the old and replace the new. i have the keys for both.thanks guys
Old Nov 6, 2012 | 12:48 PM
Best advice I can give you is read the shop manual.
You can download one at MyMopar for free:
but the page numbers do not follow the "dash" numbering, so you'll have to play with the page numbers in your viewer to find where you want
"AbodyJoe" posted this on a 70's Dart, should be similar:
http://www.bigblockdart.com/forum/sh...umn-to-another
Old Nov 14, 2012 | 05:45 AM
Chryco Psycho's Avatar
if it is in the column assuming it is a 70 you need to remove the steering wheel then the turn signal switch needs to be pulled up as well then remove the 4 screws securing the upper housing & slide it up out of the way & you will see a triangular plate holding the lock tab down , remove that plate & there is a small hole under the plate , use a pin punch & press down on the retainer & slide the lock out , the column can be reassembled & the lock just snaps in .
a.johansson84
May 27, 2012 03:30 AM
Rmmiles
Oct 19, 2011 10:41 PM
Tiretrack
Jul 10, 2010 08:14 PM
GMdude
Jul 9, 2009 04:42 PM
ngc414
Jul 7, 2009 10:14 PM
