Car is dead no power.
Old 01-12-2010 | 12:04 AM
sgnrulz's Avatar
Ok so my friends and i went out to day to kinda christen the newport as the new fun car of the group.
We went to go eat got back to car went to start it. There was nothing.
So we called a friends dad who lived down the street he came to give us a jump.
Nothing no headlights no interior lights not a bump from the starter.
But my horn still works.
And if you run connect hots on the little solenoid, relay whatever the thing is that the positive lead from the battery runs too the car cranks. But wont start.
Any ideas or directions from here?
Kinda need the car running by 1 o'clock tomorrow.
My girlfriend has my truck out of town.
Is it a fuseable link perhaps?
or could it be that little solenoid switch thing?
Old 01-12-2010 | 04:54 AM
Sounds like it could be the starter relay for starters. Are you getting fuel and spark?
Old 01-12-2010 | 07:14 AM
6fury4's Avatar
Member
Cranks but won't start? That part of it sounds like the ballast resistor. Ceramic thingy on the firewall. LOL
Old 01-12-2010 | 07:29 AM
samuelcosmo76's Avatar
Check the simple stuff! All the connections!
Old 01-12-2010 | 10:07 AM
sgnrulz's Avatar
Cranks when i run power through starter relay.
I have no power what so ever pretty sure ballast resistor i would still have lights.
I have power to my fuse box.
Im completely stumped right now.
Old 01-12-2010 | 02:50 PM
check all your connections for any corrosion
Old 01-12-2010 | 04:52 PM
scotts74birds's Avatar
What car, and do you have a voltage tester?
Old 01-12-2010 | 06:28 PM
actually, now that i read this post again, i remember having a similar problem. the lights and everything worked, but it wouldn't crank... it turned out to be a bad connection at the battery terminal. all the connections in my car are crimped, and i think one of them popped out.
Old 01-12-2010 | 07:24 PM
hypo1's Avatar
i had a problem with my starter relay.everything else worked.you could start the car by hotwire thru the relay as long as the key was on.bad connections or faulty ignition switch would be my guess
Old 01-12-2010 | 10:26 PM
sgnrulz's Avatar
but i have no power nothing works.
Old 01-13-2010 | 02:03 AM
hypo1's Avatar
it could be the switch. if the switch if the switch is faulty nothing will work
Old 01-13-2010 | 10:24 AM
sgnrulz's Avatar
I have no power to my fuse box. Had terrible day yesterday couldn't get to car really.
But yeah no power to my fuse box which i believe means it is a faulty wire or fusible link.
Old 01-13-2010 | 11:50 AM
sgnrulz's Avatar
unscrewed fuse box.
pulled assumed bad wire tested it where it connects to fuse box.
It was bad tested it about an inch up plugged it back in so wouldn't forget the spot. (was going to get wire cutters.) it sparked plugged key in turned it. Car fired right up.
So i just cut it and put a new connector on it cars fine now.
Im a very angry person right now.
Chrysler
02-28-2013 06:23 PM
mystarcollectorcar.com
11-06-2010 04:14 PM
1923tbucket
07-20-2010 02:46 PM
kylem4711
03-10-2010 06:20 PM
deadkelly
10-30-2009 08:57 PM
Quick Reply: Car is dead no power.
