charging problems
Old Mar 31, 2010 | 03:56 PM
get2sm's Avatar
Junior Member
charging problems
I`m having some charging problems.All winter I`ve went out to garage and car started fine.Took it out for drive other day shut it off and battery was dead.I jumped it started right up.Took it to get alternator checked said it was bad.So I took it off had checked again and it was good.So I bought voltage regulator changed it.When I check batt. volt with car off its 12.6 when I start it drops to about 11.When I check alt. volts it jumps all over place.I`ve checked all grounds I can think of.Looked goodchecked wires dont see anything that looks bad.Tried different battery no change.Anyone that has an idea would be much appreciated.Thanks
Old Mar 31, 2010 | 05:14 PM
1966sportfury's Avatar
A.K.A Bob Dodge
sounds like a short in the car. the alt could actually have a short in it. did u use a dmm to check the volts or the factory guage?
Old Apr 1, 2010 | 12:37 PM
get2sm's Avatar
Junior Member
I used a volt meter
xvodysseusvx
Jun 25, 2018 04:38 PM
Trapper22
Dec 15, 2011 08:45 PM
rockman
Jul 6, 2010 07:02 AM
hypermite
Mar 22, 2009 10:08 AM
69RoadRunner383
Feb 21, 2008 10:50 AM
