Richmond center
Old Dec 8, 2011 | 04:57 AM
62Furious's Avatar
Richmond center
has any one used this type of center section from Richmond, where you take out the spider gears from an open to make a posi
Old Dec 8, 2011 | 08:19 AM
Nope but looks cool. Take lots of pictures for everyone else. Thanks in advance.
Old Dec 8, 2011 | 09:16 AM
That is not a posi, that is what they call a lunch box locker or ratching locker. Yes it replaces the spider and side gears but it does not use any clutch packs. There are teeth that will lock together when going straight. when you turn and have no power being applyied, the teeth are designed to rachet against each other allowing the tires to turn at different speeds.
These have been used if 4x4 vehicles for years as a cheap alternative to full lockers.
Old Dec 8, 2011 | 10:03 AM
What about strength of those gears?
Old Dec 9, 2011 | 05:00 AM
62Furious's Avatar
OK So when I put the rubber to the pavement will I have two marks or one wheel, the paper work said that it locks the wheels when going streight
Old Dec 9, 2011 | 07:37 AM
John Van's Avatar
It's a locker, it will leave marks from both tires when doing a burn-out. john
Old Dec 9, 2011 | 08:04 AM
That's a good thing.
freightdog319
Jul 29, 2014 06:05 PM
67hemidart
Oct 10, 2012 05:36 PM
reddogg6809
Aug 15, 2009 06:42 PM
gotdust
Jan 31, 2008 12:33 PM
joflaig
Apr 26, 2007 06:19 PM
