Starting issue dodge w150
Old Aug 4, 2019 | 03:37 PM
Michael Faecher's Avatar
1988 Dodge W150 318. Started hard starting recently. When key is turned it barely turns over, turns slow and you think its going to start clicking telling you battery is dead but after 5 seconds it speeds up and fires up. I cleaned battery terminals so far. Also the d/c battery gauge on dash is stuck in the middle. Doesn't move. Don't know if this is related. I also tested alternator with meter and its putting out over 13 volts. So its ok. Any help is appreciated. Thank you.
Old Aug 4, 2019 | 03:42 PM
I'd check the timing or the starter could be taking a dive.
Old Aug 4, 2019 | 07:27 PM
Welcome.... What were the test numbers on the starter and the battery ?
Old Aug 4, 2019 | 07:33 PM
It started raining before I could finish. I will finish readings tomorrow and reply with exact numbers
Old Aug 4, 2019 | 07:37 PM
We are here to lend a helping hand...
Old Aug 5, 2019 | 01:30 PM
Solved
Went to start truck to do tests. I could see battery while starting it. I noticed smoke coming from negative terminal while starting. Negative cable seamed tight cuz I couldn't tighten it down any further but wasn't tight enough. Went and bought new terminal and all is good. Easy cheap fix. I feel stupid even posting the problem now. Thanks for the help anyway.
Old Aug 5, 2019 | 09:37 PM
Clean all the cable ends..... Clean all the cable surface's... Clean and make sure all the grounds are good and tight and clean.. And you might just be amazed hoe things start coming around... Even with the grounds for the lights and Body start having issues.... Chip chipping at it.. Glad you got it turning easier..
Old Aug 6, 2019 | 10:28 AM
indeed! it got to the point i'd buy cable ends when i worked at autozone just to help customers out who came in with those suckers fried. they weren't much and it's suuuuuch an easy fix. i've gotten a LOT of people back on the road with ends i carry around.
1970DusterUSMC340
Jan 12, 2018 01:07 PM
switherow
Aug 28, 2014 11:57 AM
rookie440
Jun 27, 2011 08:09 PM
alsparl
Jul 7, 2009 03:39 AM
siliconcrunch
Apr 8, 2008 10:17 AM
