throttle linkage
The stock cable and linkage should be pretty simple. Assuming you know where it bolts on (usually the manifold bolts), adjust the cable on linkage so there is a little bit of slack with the gas pedal in the rest/idle position and lock it down. Then have some one fully depress the pedal and make sure the throttle plates are fully opening, WITHOUT the the throttle body acting as a "stop". That could damage the carb. Adjust the cable's position on the linkage as necessary.
If you need help with a kick down linkage, hopefully someone else will jump in, haven't used one in decades.
Hope that helped.
Hope that helped.
