timing questions
Old Apr 9, 2010 | 10:35 PM
tang72's Avatar
timing questions
Hey guys i just have a few questions about timing my car. As it drives right now its just "timed" by ear and well... not exactly accurate. As for motor its a 68 440 with a stock rebuild .03 over so im assuming its 10.1 compression ratio. i have a Holley 750 double pumper on top of a performer RPM air gap intake manifold, Pertronix electronic ignition, and headman long tubes going to 2.5 inch duals w/ 3 inch Flowtech Afterburners dumping before the rear axle. The cam and heads should be stock Magnum stuff. My two main questions would be how do i find the 0 degree position? The marks are not visible on the front of the engine... i think i can use TDC (top dead center) of cylinder 1 to do this but im not sure if thats what determines it. My second concern is im not too sure what the advance should be on a 440. I have a buddy thats going to time the car for me Sunday so he will show me most of what i need to know to do it myself next time but he is a chevy guy and is not too sure what he should set the timing at either. Any help would be appreciated. Thanks guys
Old Apr 10, 2010 | 02:45 AM
Polaradude's Avatar
Try 36 degrees at 2000 and go from there.
Old Apr 10, 2010 | 03:18 AM
Good advise..........
Old Apr 10, 2010 | 09:06 AM
tang72's Avatar
Sounds good... I dont have a tach in the car but i can figure it out. Thanks
Old Apr 10, 2010 | 10:58 AM
does the timing cover have the markings on it?
Old Apr 11, 2010 | 07:51 PM
tang72's Avatar
They are not really legible but i should be able get it figure out. I just ordered a hotter coil and got a set of jets in. Im going to spend next sat tuning the whole set up. Thanks guys ill start at the 36 at 2000
19newport72
Mar 27, 2024 06:44 PM
Gorts 5th
Dec 19, 2012 04:52 PM
a.johansson84
May 27, 2012 03:30 AM
Dartingtraffic
Oct 15, 2011 06:17 PM
MoparMan76
Jan 14, 2011 01:31 PM
