210+ cranking comp, 10.7 CR and '509 cam...Serious mismatched combo!
Old Jul 12, 2013 | 11:29 AM
  #31
As your finding out....the valvetrain can bite you hard if not done rite...
Keep chipping....you'll get-r-done....
Old Jul 13, 2013 | 01:26 PM
  #32
Kern Dog's Avatar
Thank you, Bob
Old Jul 13, 2013 | 02:23 PM
  #33
What gears and trans are you using Hi stall converter ?? 4 speed
Are you changing thew valve springs ?
Old Jul 15, 2013 | 08:54 PM
  #34
Kern Dog's Avatar
The car has a 727 with a Gear Vendors. The converter is a 9 3/4" unit rated at 3000 stall. The axle has a 3,91 diff, it is 3.05 in overdrive.
New springs? You bet! The Rep at Summit Racing said the springs installed in the Edelbrock heads I have are extremely close to the ones Lunati called for, so I ordered a replacement set.
Old Jul 26, 2013 | 10:49 PM
  #35
Kern Dog's Avatar
I've been busy working on another car so the Charger has had to wait. I have all the parts here and I bought a degree wheel kit.
This other car has sucked away too much time. Its a 74 Duster, original 360/E58 car. Yellow & black with rally wheels. Should be a sharp looking car when I'm done.
JETBLU
Aug 17, 2013 05:50 PM
1923tbucket
Apr 3, 2013 02:15 PM
dynaglyde
Aug 18, 2012 10:09 AM
deadkelly
Aug 30, 2009 07:24 PM
Sanitarium
Cuda Specific Discussion
Aug 16, 2008 03:44 PM
