383 to 440 headers wont fit???
Old Sep 1, 2013 | 06:05 PM
Moss's Avatar
71 roadrunner 383 factory. Dropped the 440 in today and the passenger header top tube hits the inner fender and shock tower. the same headers fit the 383 fine. I know I am taller and broader now. Anyone have suggestions? Thanks
Old Sep 1, 2013 | 07:04 PM
Ooooops....440's a raised block.....
http://www.ttiexhaust.com/
Fit like a Glove
Old Sep 2, 2013 | 01:21 PM
Moss's Avatar
Thanks Bob. 700-800 bucks and needs a mini starter and I may have to go that direction but does a hooker comp work. Same part number for 383 and 440 which makes me wonder. I know the ports are the same but the broader 440 gets closer to the inner fenders.
Old Sep 2, 2013 | 03:25 PM
Might also check Schumacher Creative.
Old Sep 2, 2013 | 04:23 PM
The Hooker super Comps must hang down lower....You would have to double check with them... But there 750 ish.... Also...
Old Apr 27, 2014 | 12:34 PM
harv65's Avatar
would 426 hemi heads fit a 440
i am new to big blocks
Old Apr 27, 2014 | 03:35 PM
moe7404's Avatar
the 426 hemi head is a LOT different. the main diff is a stud on the hemi head under the intake port. and a long ear cast in to the block that the studs go through. with stud nuts in the tappet valley. that location on a 440 head is a head bolt threading into block like the other head blots. i have seen a mod where the 440 is ground on and a long ear welded to the block to take the hemi stud.
Old Apr 27, 2014 | 09:14 PM
super comp are a larger diameter ! 2 1/4"
Tunaman
Feb 19, 2014 06:27 PM
Zorro
Aug 26, 2011 09:06 AM
mantisfactory
Jan 30, 2011 07:44 AM
getsum
Apr 25, 2010 12:21 PM
67gtxclone
Jan 21, 2010 06:08 PM
