383 throttle linkage problem
Old Jul 21, 2012 | 07:23 PM
degausser86's Avatar
I had a local mechanic put a Holley 650 carb and a Weiand intake on my 383, and he apparently rigged the throttle linkage to where the transmission hesitates to shift. I was hoping someone could look at this set up and tell me what I need to change or what parts I might need. Thank you.
Old Jul 21, 2012 | 08:10 PM
Archer's Avatar
de -
OK, that's jury rigged fer sure, and a lot of us did stuff like that in the past.
While you can tweak that to work, the best bet is to go with an after market linkage from Lokar, Holley or Edelbrock.
Happily, I'm using a manual valve body and don't have to worry about such things ...
Old Jul 27, 2012 | 12:34 PM
bboogieart's Avatar
Should look a little more like this.
It's not mine, I copied it for refference.
Old Jul 27, 2012 | 12:48 PM
bboogieart's Avatar
Just for starters the linkage needs to move. Not sure, but you may need a different bracket that holds the linkage to the manifold. This should give you and idea of what you will need. Best bet is look at as many pictures of similar set-ups.
I am guessing the guy that did this was not familiar with Mopars.
Old Jul 27, 2012 | 12:51 PM
bboogieart's Avatar
Here is what the other end should look like.
Old Jul 27, 2012 | 01:31 PM
That guy was a dummy. Your kick down linkage goes on the opposite side of the throttle linkage between the big nut and washer. Held on by the other clip.
Old Jul 27, 2012 | 04:12 PM
Look in the Holly catalog They make a bracket specifically for this !!!!
Something like this http://www.summitracing.com/parts/ED...n/?prefilter=1
Old Jul 29, 2012 | 09:08 PM
moparted's Avatar
that 2bbl stuff wont work
jabo51581
Dec 21, 2013 07:09 AM
BuckNeccid
Apr 14, 2011 10:11 PM
67Polara
May 19, 2010 06:17 PM
67Polara
Mar 1, 2010 10:12 PM
craveman
Apr 4, 2009 09:32 AM
