3RD GEN Hemi oil pump
Old 08-07-2019 | 04:03 PM
jeepers creepers's Avatar
Hi guys, i know that the 2009 up oil pump are thicker and flow about 22% more oil compared to the older ones (2003-2008), the also have larger inlet pick up hole so a newer style pick up is needed too but do you know if these fit a 2003 block? Thank you.
Old 08-09-2019 | 12:31 PM
And are the internals able to passed the increased oil with out and issue?
Old 08-09-2019 | 08:33 PM
Drag Pak's Avatar
I believe the 2009 and newer blocks have a deeper front casting and a crankshaft modification to accommodate the later/thicker oil pump.
Old 08-09-2019 | 10:45 PM
Just use a better oil, Joe Gibbs or Amsoil.........
What's wrong with this?
https://www.jegs.com/i/Melling/689/1...ampaign=Merkle - BSC - Vendor Only Searches&utm_term=4579259773231063&utm_content=Mel ling
Old 08-13-2019 | 06:32 AM
Bot sure about that, sounds like a tricky job...
Old 08-13-2019 | 06:34 AM
Seems a quality product, harder optional springs are an extra
Old 09-03-2019 | 12:51 PM
Looks like that the 6.1's oil pump has same dimensions of the 5.7's but with a different spring in it so it should be an high pressure model, any real life experience?
Old 09-03-2019 | 04:54 PM
Drag pack will be on hes the man for the gen 3 here.
Old 09-03-2019 | 06:13 PM
Drag Pak's Avatar
As is done with any good build, blend any sharp edges out of the feed side of the pump and block. Even if it is new, check the pump for internal clearances or scratches. Get rid of the factory TTY bolts and buy ARP fasteners. Toss the connecting rods in a bin.
jeepers creepers (09-06-2019)
Old 09-06-2019 | 05:35 PM
I will, thank you for the advice, i've seen pretty bad casting flashes into the drain holes too, but i definitely grind the sharp edges where oil is flowing into, did the same thing in a couple of SBC rebuild.
A little O/T but non too much, i'm reading an Hemi rebuild book so they say to upgrade the early 3rd gen engine with the newer style 2 holes main bearing , by making and additional groove and little recessed hole onto the block mains to improve lubrication, basicly just copy the main bearing style, is it really worth the effort?
Thank you
Old 09-06-2019 | 08:14 PM
Drag Pak's Avatar
Thank you
Any oiling improvements are worth the additional effort!
Old 09-07-2019 | 09:49 AM
I think so , thank you.
Old 09-07-2019 | 09:59 AM
This doesn't only apply to any one engine family or brand.....
newto440
17
12-09-2019 07:38 PM
CRinWP
43
11-13-2014 06:36 PM
1968newport
08-05-2013 08:53 PM
Moss
28
07-15-2013 06:57 PM
bushwood
07-01-2011 04:42 AM
