3RD GEN Hemi oil pump
Old Aug 7, 2019 | 03:03 PM
jeepers creepers's Avatar
Hi guys, i know that the 2009 up oil pump are thicker and flow about 22% more oil compared to the older ones (2003-2008), the also have larger inlet pick up hole so a newer style pick up is needed too but do you know if these fit a 2003 block? Thank you.
Old Aug 9, 2019 | 11:31 AM
And are the internals able to passed the increased oil with out and issue?
Old Aug 9, 2019 | 07:33 PM
Drag Pak's Avatar
I believe the 2009 and newer blocks have a deeper front casting and a crankshaft modification to accommodate the later/thicker oil pump.
Old Aug 9, 2019 | 09:45 PM
Just use a better oil, Joe Gibbs or Amsoil.........
What's wrong with this?
https://www.jegs.com/i/Melling/689/1...ampaign=Merkle - BSC - Vendor Only Searches&utm_term=4579259773231063&utm_content=Mel ling
Old Aug 13, 2019 | 05:32 AM
Bot sure about that, sounds like a tricky job...
Old Aug 13, 2019 | 05:34 AM
Seems a quality product, harder optional springs are an extra
Old Sep 3, 2019 | 11:51 AM
Looks like that the 6.1's oil pump has same dimensions of the 5.7's but with a different spring in it so it should be an high pressure model, any real life experience?
Old Sep 3, 2019 | 03:54 PM
Drag pack will be on hes the man for the gen 3 here.
Old Sep 3, 2019 | 05:13 PM
Drag Pak's Avatar
As is done with any good build, blend any sharp edges out of the feed side of the pump and block. Even if it is new, check the pump for internal clearances or scratches. Get rid of the factory TTY bolts and buy ARP fasteners. Toss the connecting rods in a bin.
Old Sep 6, 2019 | 04:35 PM
I will, thank you for the advice, i've seen pretty bad casting flashes into the drain holes too, but i definitely grind the sharp edges where oil is flowing into, did the same thing in a couple of SBC rebuild.
A little O/T but non too much, i'm reading an Hemi rebuild book so they say to upgrade the early 3rd gen engine with the newer style 2 holes main bearing , by making and additional groove and little recessed hole onto the block mains to improve lubrication, basicly just copy the main bearing style, is it really worth the effort?
Thank you
Old Sep 6, 2019 | 07:14 PM
Drag Pak's Avatar
Thank you
Any oiling improvements are worth the additional effort!
Old Sep 7, 2019 | 08:49 AM
I think so , thank you.
Old Sep 7, 2019 | 08:59 AM
This doesn't only apply to any one engine family or brand.....
newto440
17
Dec 9, 2019 06:38 PM
CRinWP
43
Nov 13, 2014 05:36 PM
1968newport
Aug 5, 2013 07:53 PM
Moss
28
Jul 15, 2013 05:57 PM
bushwood
Jul 1, 2011 03:42 AM
