440 starting problem
Old May 22, 2019 | 09:53 AM
Stevie d's Avatar
Hi, new to the forum I have a 1966 Dodge Charger that has a 440 big block when I start and run it for a while then cut it off I can’t get it restarted and the coil has no spark so I changed the coil started it let it run cut it off and it’s doing the same thing I don’t think it’s the carb it’s new so I think it’s an electrical issue somewhere any help would be great so frustrating thanks
Old May 24, 2019 | 07:16 AM
Use a test light and see if you are loosing power to the coil when this happens? If thats is the case, Check the power at the ignition switch for the same.
groucho
May 6, 2014 09:57 PM
Dominic Torreto
Jul 29, 2012 10:07 AM
twisted68
Jul 13, 2012 07:46 PM
raceware
May 16, 2008 04:50 AM
built440
Oct 11, 2007 05:45 PM
