'68 383 Sparkly oil :mad:
Old Feb 15, 2018 | 11:02 AM
70newport's Avatar
Motor is a '68 383, comp cams hydraulic flat tappet cam with 1.5 ratio adjustable roller rockers, block is bored 30 over with Keith black pistons, about 9.2:1 compression etc. Pretty common street build IMO. Bottom end was done about 2 years ago and it still seems to run good.
So at the end of this past summer I changed my oil (like I do for every winter before I park my car) and saw little sparkly bits in my drain pan......
Last driving season I did notice what I think to be my lifters seemed a little on the noisy side my last couple times of driving so I assumed this was my issue.
I am finally getting the time to take a look at this so I have pulled my top end apart and all of my lifters look to be in great shape, rocker arms were all still nice and tight. Im terrified to ask but any suggestions on where to start looking now?
Any direction would be great thanks.
Old Feb 15, 2018 | 12:52 PM
Drag Pak's Avatar
Put a straight edge across the bottom of the lifters. There shouldn't be any light under the straight edge
Look inside the oil pump.
Old Feb 15, 2018 | 04:50 PM
Can you pick up the particles with a magnet?
Old Feb 15, 2018 | 07:52 PM
Look at the cam for sharp edges?
Brassy Color?
Old Feb 16, 2018 | 05:10 AM
Pull out your dist/oil pump drive and have a look.
Old Feb 16, 2018 | 10:16 AM
Drag Pak's Avatar
And there is the much overlooked fuel pump pushrod.
Old Feb 16, 2018 | 11:47 AM
70newport's Avatar
thanks everyone, Im away for a snowboard trip till monday but monday night i will get my fuel and oil pump pulled out. And see if I can pick up the particles with a magnet. etc.
thanks,
Old Feb 16, 2018 | 06:42 PM
Good Point....
Morgan Gilbert
May 31, 2016 09:38 PM
78trailduster
Mar 30, 2009 03:30 AM
dzltd02
Oct 28, 2008 08:25 AM
robertoil
Jan 25, 2008 05:34 PM
