79 Dodge back firing
Old Sep 13, 2012 | 06:39 PM
Mudslinging's Avatar
My 79 D100 pick up with a 318 and holley 650 backs fires when I accelerate hard. When I drive normal it doesn't do it. It does it for a while then it doesn't do it for a while. Could it be carburator or timing? Any imput will be appreciate.
Old Sep 13, 2012 | 08:05 PM
mikerp76's Avatar
is it backfiring out the carb or the exhaust?
Old Sep 14, 2012 | 08:37 PM
I feel it in the exhaust. Its weird, it was doing it a lot when I step on it, it would back fire bad, as soon as I back off on the accelerator it would go away, then it stopped doing it for a while. Now started back up again. It almost feels like, when the secondaries open up, that is when the back firing starts. On a side note, a couple of times I had problems with the secondaries staying wide open and had to shut the truck off to giggle the mechanism that the secondaries sit on to get them to close. So I was thinking carburetor.
Old Sep 14, 2012 | 09:22 PM
mikerp76's Avatar
it could be getting too much fuel which could cause the problem
Old Sep 15, 2012 | 06:03 AM
Thanks mike76, I will send the carb for rebuilding. Do you have any place in particular that rebuild carbs.
Old Sep 15, 2012 | 08:46 AM
Sounds like too much fuel and your timing may need to be advanced a degree or two.
Old Sep 16, 2012 | 08:15 AM
Gorts 5th's Avatar
Smile
if he s getin a back fire out the tail pipe its to advanced the.. timing. what might be happening is your vacuum is hooked up to a port that is advancing it to quickly and causing the tail pipe back fire but also if your secondaries are sticking open thats a red flag for a bad or incorrectly modified carb could be all your problems you have a few things to check
Old Sep 16, 2012 | 02:30 PM
mikerp76's Avatar
i know you can get a carb kit from any aouto paarts sorte in your area. as for who could rebuild it for you i would call around some of your local shops or try to find out if one ofour members here know how to do it that may live close by. i do all the carb work on my car myself. it's not that complicated as it may seem. just be sure to take your time and tey to remember what went where.
Wolfpack
May 5, 2011 04:05 PM
vintagenc2
Aug 6, 2010 02:13 PM
mack.902
Jul 17, 2010 03:13 PM
timmie124
Jun 27, 2010 11:05 PM
KJoeZ61
Oct 28, 2009 12:49 PM
