cam and compression question
Old Apr 6, 2014 | 09:43 AM
440 aspen's Avatar
I found pistons I want to get (Probe SRS Forged Pistons 12498-040) and used a compression calculator and came up with 10.02:1. With the 509/292 cam, would this be too much compression for pump gas with 452 heads, or would the duration bleed off enough pressure that I could get away with it? thanks
Old Apr 6, 2014 | 10:35 AM
Mr.4spd's Avatar
If you keep the motor cool, have 93 octane available, and back the timing off a bit you may be okay. Bolt up some aluminum heads and you'll be golden
Old Apr 6, 2014 | 11:34 AM
440 aspen's Avatar
On a hot day (around 95) moving a run at about 190. I dont see very much stop and go except when im in town but I try to stay in bfe as much as i can. 93 octane is about a 1 min drive my house and if I had the money I would already have aluminum heads. Thanks for makin my day just a little better
Old Apr 6, 2014 | 12:18 PM
Yes.... 10.1.1 CR you can still use Pump gas on the old Yankee motors...
Old Apr 6, 2014 | 09:49 PM
You need 10/1 for that cam! And a set of 3.91 gears
josehf34
13
Jan 13, 2014 09:35 AM
Air Bubba
Jan 17, 2013 09:54 AM
Altosax
Oct 7, 2011 04:59 PM
69POLARA383
Jul 16, 2011 07:36 PM
Slice
May 21, 2011 08:10 PM
