Carb upgrade - 2 barrel to 4 barrel
Old Aug 8, 2012 | 02:29 PM
Polara-Lee's Avatar
I am thinking of ugrading my carb from the standard 2 barrel Carter carb on my 68 Dodge Polara (383), I feel it just needs a bit more power, any recommendations on the best 4 barrel carb brand size to go for holley, carter etc, been having a look and it seems theres many options..... the engine is the stock factory 383 with original 2 barrel carter carb, any help/advice would be great, cheers
Old Aug 8, 2012 | 04:33 PM
600 CFM is probably the biggest you want to go. Get you an Eddy Performer or RPM Performer intake.
Old Aug 8, 2012 | 09:25 PM
Silverick's Avatar
Agreed. An Edelbrock Performer carb with a Performer intake....
Old Aug 8, 2012 | 10:18 PM
moparted's Avatar
and gain 5 hp
Old Aug 9, 2012 | 02:30 PM
Polara-Lee's Avatar
OK will check it out, thanks for the help
Just had a quick look, any ideas which model is best fit, seems theres a few choices, looking at the 14064,1405 & 1406
Old Aug 13, 2012 | 03:14 AM
14064 - This is the "shiny" version of the 1406
1405 - This is the basic that Edlebrock puts out and has a manual choke
1406 - This is the same as 1405 except instead of a manual choke, it is electric.
If this is a show only car, spend the money on 14064. If this is a car that you drive around then I'd go with the 1406, wire in the electric choke and call it good. Also go with a Edlebrock Performer intake and a new air filter kit. This will help build some power. After that think about going with a set of headers to help exhaust all that fuel and air your new intake system will want to feed the motor.
Old Aug 18, 2012 | 02:11 PM
Polara-Lee's Avatar
OK thanks for that info, looks like a 1406 will be best fit, as its defintely not a show car :-)
Old Aug 18, 2012 | 05:31 PM
Gorts 5th's Avatar
Talking
if its a stock set up i agree 1405
or try the 1805 650 its a spread bore and avs
i use that on a air gap rpm feeding a 318
Old Jun 17, 2020 | 02:55 PM
Your running E-85?
Old Jun 18, 2020 | 09:41 AM
yeaaaaaaaaah, you won't see too much power out of this, but i'm sure something. oddly, the biggest power gain i got out of my '68 was removing the mechanical fan in favor of an elec job. i could feeeeeel that modification in the driver seat.
Duster360
Mar 10, 2012 12:39 PM
mopsled
Dec 20, 2009 06:43 AM
68camperspecial
Sep 18, 2009 12:45 PM
ken g
May 17, 2009 06:16 AM
skymynx
Nov 12, 2008 09:55 AM
