Converting to fuel injection, need help
Old Mar 28, 2012 | 07:32 PM
Nightmare's Avatar
Currently I have a 318 v8 4 barrel carb in my charger. I use it as a daily driver, everytime I start it I have to let it warm up , then I have to pump it up when I'm at a red light , I live in a urban area so there's quite a few lights and stops. Overall it's just a pain in the ***, which is why I wanna go with a fuel injection setup. How much would this cost to convert over?
Old Mar 28, 2012 | 07:46 PM
I looked at four different offerings for you and they are all big bucks.
The Fast Kit from Comp Cams uses your own 4150 intake and the master kit that includes the electric fuel pump will run you $2,179.00
The MSD Atomic Kit is comparable to the Fast Kit and it costs $2,290.00 for the master kit. It can tie into a MSD 6A box and adjust the timing.
The Holley Avenger EFI with a 900 CFM throttle body is $2,054.00 for the master kit.
Then way out there is Edelbrocks Pro-Flo sets contain a 1000 cfm throttle body, a intake manifold and with fuel rails and injectors runs you $3159.00.
Old Mar 28, 2012 | 08:03 PM
Nightmare's Avatar
Oh wow
Old Mar 28, 2012 | 08:45 PM
Stock carb ?? Check and adjust the choke ???
Old Mar 28, 2012 | 11:47 PM
Nightmare's Avatar
Yea it's a stock carb. I just had the carb rebuilt and adjusted, cause the guy I had bought the car off had it misadjusted. Doesn't feel right though.
Old Mar 29, 2012 | 08:05 AM
Originally Posted by Nightmare
...............everytime I start it I have to let it warm up ,................... then I have to pump it up when I'm at a red light ,
This is a sure sign that whoever "adjusted" the carb didn't know what he was doing.
WHAT is the carb? That is what model, how old, is it an aftermarket replacement, etc?
Several things are possible. You might have a fuel delivery problem, but if it's in the carb itself there are several distinct areas
A bad accelerator pump, or one that is improperly installed can cause much of your symptoms. You must have one that has a good "leather" (synthetic cup, nowadays), is properly installed, AND has the proper check *****/ check needles installed.
Because you may be suffering fuel boil -- off during shutdown, try this: Next time you have some time, when the engine is cold, start and run it a minute or so, then shut it off.
Remove the air filter, use a flashlight if need be, and block the choke open so you can see down the throats. Move the throttle while looking down the carb throats. You should INSTANTLY see fuel being expelled from the acellerator pump nozzles as you move the throttle.
ADDITIONALLY
If the float level is too LOW, this can cause a too -- lean condition
The choke could be misadjusted so far as the cold condition
The idle mixture could be way too lean, or
PASSAGES in the carb could still be plugged with goop even though it has been "cleaned."
Here's another thought----- if you are shakey on maintaining carbs, WHAT are you gonna do when your aftermarket EFI gives trouble? I can assure you that most mechanics won't want to have anything to do with it.
Old Mar 29, 2012 | 09:19 AM
Archer's Avatar
NM -
440 is correct, but you might have to consider a few other facts of life first. Old style engines need a little babying from a cold start, even with a perfectly operating choke. (Guess we've all been spoiled with the newer cars, that are just turn the key and go.)
Having to pump it up at a red light is a problem. That's when you have look at 440's suggestions.
OR, switching to an Edlebrock carb will be as hassle free as you're going to get, not zero, but pretty much out the box ready. That assumes that the rest of the fuel delivery system and electrical system are intact.
Old Mar 29, 2012 | 10:28 AM
Nightmare's Avatar
It's a 650 edelbrock, it randomly stalls on me though.
This morning after driving a few minutes I had to stop to turn on the main road and it stalled on me, then after a few lights and 15 mins driving on the highway I pulled into a parking lot made a turn in the parking lot and it died on me midturn, started it back up, drove down to pull into a spot , threw it in reverse and as I'm backing up it died again. What the ****. I know the ignition is fine, and the guy at my local shop who sent the carburetor out to the carb shop says "these things take a few adjustments before they get right". How do you not notice something like this on a test drive?
Old Mar 29, 2012 | 03:49 PM
You need to find a new "carb man," he doesn't know what he's talking about
Is it fairly warm (80s, higher) where you are? Could also be fuel boiling/ vapor lock or some other fuel deliveray problem.
Old Mar 29, 2012 | 04:26 PM
440 probably nailed it. I say vapor lock also. One quick way to check is to add a half inch phenolic spacer under the carb and if the syptoms go away then you know the fuel was boiling away.
Old Mar 29, 2012 | 08:52 PM
Nightmare's Avatar
The car finally crapped out on me tonight, wouldnt even start or turn over nothing, but i checked the headlight wires on the battery an it still had juice in it.The problem I've noticed is that the car will only idle in park, when I have it in drive and I'm stopped at a red light or have to slow down the car wants to stall.
The guy I bought the car off of had misadjusted the carb, which is why I had it sent out to be fixed. Apparently they don't know what the frick their doing over there cause I don't know how You could adjust it AND road test it and not notice the car trying to stall.
I go to school for auto mechanics, this is my first carburetor car, I told my teacher what's been happening and he said the idler or something under the air cleaner is not open enough and that's probably why the car won't idle under a load.
I'm still learning and I probably don't know half as much as most of you guys so any advice or insight is appreciated.
Old Mar 30, 2012 | 04:09 AM
PK1's Avatar
PK1
Its an Eddy correct?
And your in school for auto tech? Good for you, good career!
Time for you to start with your collection of tools. Or ask your teacher for a loaner.
You need a vacuum gauge. 15-50 bucks depending on quality.
Then follow this procedure for the carb. ( Someone pipe in if im wrong here, Ive been dealing with injection for many moons now).
-Car off, in park, wheels chocked.
-Turn both idle air screws in front of carb all the way in clockwise. Bottom them out.
-Turn both out 2 full rotations. So counter clockwise for two rotations of the clock. -Do not pay attention to the orientation of the screw driver slot in the head of the screw. Machining tolerance will have both screws in different orientation.
-Start car.
-Adjust idle screw so your car is running fast idle. 800 plus rpm.
-Let it warm up.
-Once car is warm and water if flowing bring idle screw to desired idle 700rpm or what you like. (You will have to play with the setting to best fit your combo)
-Connect the vacuum gauge to a port in the intake UNDER the carb throttle blades. -You want constant vacuum.
-Then adjust each screw independently and watch the gauge. You want highest vacuum reading. Once both screws are set, readjust idle.
-Then get in and put car in gear, foot on break, read ilde rpm. If too low, turn car off and make small adjustments to car idle screw. No more than 1/8 turn at a time. A little adjustment goes a long way.
Good luck with school!
Old Mar 30, 2012 | 04:35 AM
Nightmare's Avatar
Thanks@PK
I'll try that.
Old Mar 30, 2012 | 05:32 AM
Archer's Avatar
Night -
What PK suggested is pretty a basic carb set up. If that doesn't work, and it may not, it implies that the is something either physically wrong with the carb or the problem is somewhere else in the fuel delivery system (that includes the fuel line itself).
The other thing you might want to look for is a simple vacuum leak. A small one might not be noticeable with a vac gauge. Applay a soapy water solution or quick start to vacuum line ends and manifold gaskets and listen for changes in rpm. It's not likely, but should be ruled out. (You do have all the unused vac ports sealed, right?)
The Edebrocks are known for out of the box performance, with little (not zero) adjustments).
Lastly, did you ever check for a fuel smell when the car stalls? That alone is pretty diagnostic.
Old Mar 30, 2012 | 08:58 AM
In addition to what PK1 posted,
FIRST set the timing. Or at least check it. If you have a fairly stock cam, I'd start with around 10* at idle speed, with the vacuum line disconnected. If you cannot get the idle down far enough to set timing, just rough it in for now, do the best you can with the carb, THEN reset the timing afterwards and LAST retouch the carb adjustment
you will have to go "back and forth" between
adjust the idle speed
adjust the two mixture screws for max RPM / max vacuum
readjust idle speed
re-adjust mixture screws
readjust idle speed last.
It MAY be possible that you have a vacuum leak, a carb problem (dirt, gum, wrong float level, or fuel dripping over into the throttle bores, etc, etc)
Old Mar 30, 2012 | 10:22 AM
A stuck float flooding the car out will make it stumble. Been there done that. If that's the case a quick oil change is in order. I would check the oil for a gasoline smell just for SAG's.
Old Mar 30, 2012 | 06:46 PM
scotts74birds's Avatar
For what they quoted for an aftermarket F.I. system, you could install a 5.2, or 5.9 F.I. Magnum motor with a compatible cam upgrade.
As far as keeping the carb and tuning it, I cant give you better than what has already been said. Good advice guys!
Old Mar 30, 2012 | 11:09 PM
Nightmare's Avatar
I just changed the oil last week, and I haven't smelled anything like gas lately.
Currently: the car is back at the shop getting the carb adjusted right (for free). If they mess it up this time I'm just gonna do it myself.
I have kind of a dumb question. Since you have to keep your foot on the gas pedal to feed fuel to the carb, how come if I'm stopped at a light and I have the car in drive, why do I have to keep my foot on the gas to keep it running but if I have it in park it'll stay running without even being in the car.
Old Mar 31, 2012 | 07:19 AM
Archer's Avatar
Night -
Ah, no. The carb has an idle circuit that feeds fuel due to engine vacuum. You don't have to keep your foot on the gas. The reason you don't have problems in park/neutral is because there's no load on the engine, and it's getting enough fuel or spark to keep it going. In gear, you're not getting enough fuel/spark to keep it running due to the extra load (engaging the tranny).
Old Mar 31, 2012 | 08:22 AM
As above, additionally, that is why I mentioned that after you get the carb roughed in close enough to keep it running (if needed) you check the timing, then reset the carb
CURB IDLE SHOULD always be checked LAST IN GEAR
So tuneup order is:
(After diagnosis and parts replacement)
1 Set point gap and dwell
2 set timing
3 warm engine, and "rough" in idle speed if needed, then adjust carb mixture
go back and forth if necessary, mixture/ idle speed/ mixture / idle speed
4 set idle speed LAST and check idle speed IN DRIVE LAST
Old Mar 31, 2012 | 10:43 AM
Nightmare's Avatar
Originally Posted by Archer
Night -
Oh ok, I just figured there would be like a backup line or valve or something that would pick up the slack.
79woodnick
Oct 21, 2021 06:23 PM
AnthonyGW0114
Nov 23, 2011 02:00 PM
cuda0872
Sep 23, 2010 02:35 AM
zekebracing
Dec 28, 2009 03:00 PM
chrisd
Apr 15, 2008 05:55 PM
