Distributor Install Advice
Old Feb 17, 2013 | 06:08 PM
buttton's Avatar
I am getting ready to swap out my points for a pro-billet "ready to run" distributor. Its a stock 1969 LA 318. I think I can handle the install OK as long as everything fits, and thats my question for anyone who has done this.
Is it really ready to run? Just line it up, drop it in, and wire it to the coil? I tried to attach an image to this post, not sure if it will show.
Thanks.
Old Feb 17, 2013 | 11:11 PM
Follow the directions and it will be close enough to work. After the install you should set it with a timing light
Old Feb 18, 2013 | 06:23 AM
pro-tech's Avatar
Bring the rotor to #1 cylinder on the distributor in the car and the line the new distributor to the same position hook up the wires as they say and then time the engine.And your done
Old Feb 18, 2013 | 02:33 PM
buttton's Avatar
The install part I can handle, the new distributor didnt come with any instructions anyway. I was just wondering if anyone else had done this and if they had any trouble with the fit. Thanks
Old Feb 23, 2013 | 05:13 AM
Gorts 5th's Avatar
Smile
here are the instructions. read them care fully
http://www.summitracing.com/parts/ms...ons/make/dodge
Old Feb 23, 2013 | 05:19 AM
pro-tech's Avatar
I put a MSD and it fit and ran great. Its a very simple proceedure. Try it then you'll know.
68GTX440
Sep 21, 2013 01:10 PM
Rumblefish318
Jun 26, 2013 05:24 PM
buttton
18
Mar 1, 2013 06:22 PM
fmontez1
Jan 5, 2012 09:21 AM
johnzdad
Sep 19, 2011 06:17 PM
