Engine block deck surface
Old Jun 1, 2014 | 07:58 PM
mrzods13's Avatar
What would be good to get all of the old gasket off of the block side. My father in law said to use a whiz wheel, I was using a razor to scrap it off but I know it has to be very clean before putting on the new head gaskets and heads which were redone.
Old Jun 2, 2014 | 09:13 AM
Sometimes this helps....
http://www.eastwood.com/crc-gasket-r...FQVqfgod2QoAcw
Old Jun 2, 2014 | 03:18 PM
pro-tech's Avatar
I have seen a lot of guys use 220 grit sand paper with a sanding block to clean gasket surfaces after cleaning the bulk of the gaskets off the way you are doing it... With a scraper or razor blade....Bill
Old Jun 2, 2014 | 06:01 PM
Take it to machine shop and have the block decked .010 to square it up and get the proper gasket surface for your new head gaskets.
I would use an 80 grit wet/dry and then a thorough cleaning
rockinhlabs
Aug 29, 2012 10:15 AM
scotts74birds
Sep 14, 2010 09:46 PM
FS212
Jun 3, 2010 11:48 AM
67gtxclone
May 30, 2010 04:46 PM
deadkelly
Oct 9, 2008 02:01 AM
