Fuel Pump Help
Old Apr 11, 2021 | 04:07 PM
MTBob's Avatar
Fuel Pump Help
Replacing mechanical fuel pump in 77 dodge 1 ton truck w/ a 440.
I have replaced mechanical fuel pumps on various engines, so I feel like I know what I am doing. I can not get this idiot thing in there. The old pump had the lever snap off. I am assuming it is in the oil pan as it is not anywhere I can see it through the mounting boss.
Is there a trick? I have compared the two pumps I even measured them, center to center on the mounting holes, and it is exactly the same.
Napa part number B-0130-P if anyone wants to double check. TIA!!
Old Apr 11, 2021 | 06:06 PM
Welcome. The fuel pump lever must go under a push rod that drives it, this rod may have slid down and needs to be pushed back up against the camshaft eccentric. Turning the engine so the rod is fully up will help, adding some grease to the rod will hold it up.
joyner29
Feb 15, 2019 03:10 AM
Dustin LaRoche
Aug 17, 2014 11:39 AM
josehf34
Dec 15, 2013 04:52 PM
jhart21
Apr 12, 2010 04:57 PM
Rosfrei
Oct 3, 2009 08:49 AM
