help! doesn't start
help! doesn't start
Hi all,
1967 Plymouth Fury III 383 engine.
It was running fine, until one day while driving, a loud backfire, engine died.
since then, replaced:
coil, fuel filter, fuel pump, distributor, spark plugs, timing chain. all band new.
rotor points to #1 cylinder on compression stroke at TDC
timing mark lines up with damper
have sparks, have fuel, fully charged battery.
Compression:
cylinder 1: 100 psi
cylinder 2: 50 psi
cylinder 3: 95 psi
cylinder 4: 105 psi
cylinder 5: 0 psi
cylinder 6: 100 psi
cylinder 7: unknown, can't get to it.
cylinder 8: 110 psi.
cranks and cranks, but won't start.
please help.
Compression:
cylinder 1: 100 psi
cylinder 2: 50 psi
cylinder 3: 95 psi
cylinder 4: 105 psi
cylinder 5: 0 psi
cylinder 6: 100 psi
please help.
Hi, I just re-tested compression on #5, it is 120.
Compression:
cylinder 1: 100 psi
cylinder 2: 50 psi
cylinder 3: 95 psi
cylinder 4: 105 psi
cylinder 5: 120 psi
cylinder 6: 100 psi
what else could be the culprit?
Compression:
cylinder 1: 100 psi
cylinder 2: 50 psi
cylinder 3: 95 psi
cylinder 4: 105 psi
cylinder 5: 120 psi
cylinder 6: 100 psi
new timing chain.
when I installed it, I made sure dots on gears are lined up: top gear at 6 o'clock, bottom gear at 12 o'clock.
also, right now, rotor points at #1 cylinder when 1st cylinder is TDC on compression stroke.
Update.
I was so focused on the timing chain, distributor, overlooked the carburetor, until a friend of mine came over, and discovered that the choke plate was jammed closed.
After freeing the choke plate, it WANTED to start.... so close..... I can feel it, it so wants to start. I think I fueled the cylinders by cranking it so much. gona give it a rest then try again.
I think we are onto something here.
rpinok
Mar 12, 2010 05:29 PM
