high idle when hot
Old May 24, 2014 | 05:29 PM
minibeer's Avatar
Question high idle when hot
my 73 340 duster has a 1407 edelbrock carb on it. car idle fine when 1st started and cold, but as I drive it and it gets hot , it seems to idle high when stopped at a light or whatever,mild build , headers , wiend manifold,by the way no choke on it. any ideas ? thanks
Old May 24, 2014 | 05:55 PM
moe7404's Avatar
first thing to try. check for a vacuum leek. 1. with engine running spray some WD-40 around the base. if it has a leek the RPM will change. and you might hear the WD-40 going in to the carb. 2. get a small vacuum hose. put one end in your ear. pass the other end over the base edges. if it has a leek you will hear it.
Old May 24, 2014 | 06:19 PM
Too lean !
Old May 24, 2014 | 06:44 PM
minibeer's Avatar
Originally Posted by TVLynn
Too lean !
sort of new to this car, and I am not a full mechanic. if carb is to lean , what adjustment should I make? thanks
Old May 24, 2014 | 08:13 PM
moe7404's Avatar
it just came to me. you may have put a square bore carb on a spread bore manifold. this will make the engine VERY lean. if this is the case you might need a specl steel plate with a specl gasket on the bottom that comes with the plate. and a regular gasket between the carb and specl plate. edelbrock has the plate you need. EDIT: i just checked a wiend 8007 is a spread bore manifold....... a 8022 is a square bore manifold.
Old May 25, 2014 | 07:14 AM
I agree... Lean or vacuum leak....
Might try opening up the Idle Air mixture screws 2 more turns and see if that helps..
Old May 26, 2014 | 02:17 PM
minibeer's Avatar
just went for a ride its 85 degrees here. I noticed when I come up to a light , the idle is high , not real bad , but definitly noticeable. while stopped I give the throttle a quick blip and the idle returns to normal. its almost when you are cold , with a choke and idling high when you start up, then you kick her down after a warm up and you are @ normal idle. so maybe a carb linkage slight adjustment ?? edelbrock 1407 with no choke ------ not finding any vac leaks. have not tryed the idle air mix screw yet, just want to rule out any other small adjustments
Old May 26, 2014 | 07:33 PM
minibeer's Avatar
Question
did some you tube research on this and the edelbrock guys are calling this idle surge which like you guys say to lean, i have never had an eddy carb on a car and this was on my car when i bought it so not totally in the know on adjustments.eddy guy says to adjust air idle screws. which way should i turn them to lean things out?? thanks for help
Old May 26, 2014 | 07:42 PM
moe7404's Avatar
i if it is lean at idle, as it is idling cover the air horn with your hand, it will increase RPM, if it is lean.
Old May 27, 2014 | 04:32 AM
Check the mixture screws should be at least 2 turns out. Make sure the return spring has enough tension
JS23
Dec 18, 2014 07:12 AM
68newportcustom
Jul 11, 2013 09:14 PM
ShowYourAuto.com
Mar 18, 2011 11:24 AM
72RDRNR
Jul 12, 2008 04:02 PM
Newf
Jun 22, 2007 09:44 PM
