Motor swap
Old Jan 3, 2014 | 10:07 AM
jwcollins86's Avatar
Motor swap
I have a 89 1/2 ton 4x4 with a 318. I recently bought a wrecked 98 1/2 ton 2wd with a 360 in it. My question is will the motor bolt up to my 89 tranny and what all do I have to do to the 98 comp and wiring harness to get everything to work. Is there any way to get the factory gauges to work?? Thanks for the help
Old Jan 3, 2014 | 06:07 PM
bigblock's Avatar
The 318 and 360 have diff torque converters and flex plates. The engine will bolt up. I would suggest using the 89 wiring but it is possible to use the 98 wiring with a lil homework. When your done with all the wiring done correctly the stock gauges will work.
Old Jan 26, 2014 | 10:51 AM
Looking for suggestions on a cam and intake swap on the 98 360.. Maybe heads too. I'm wanting to convert to a Holley 4bbl.. Any help or advice is appreciated
Old Jan 26, 2014 | 01:37 PM
moe7404's Avatar
as you all know i like holleys. an O.E.M. AFB would be easier to get right. holleys are great for making power, using lots of fuel, making you spend tons of time getting them right. of course you do know iam VERY prjudices.
Old Jan 26, 2014 | 02:00 PM
Stroker kit the 318....
Or
Stroker kit the 360
You will like it allot....
Old Jan 26, 2014 | 02:37 PM
pro-tech's Avatar
The 89 is a LA motor and the 98 is a magnium the 98 is also multi port fuel injected and the 89 is carburated. Right???
Old Jan 26, 2014 | 03:07 PM
What kind of stroker kit should I look at for the 360?
Yes it is a multi port but I'm worried about having trouble with all the electronics so that's why I wanted to go with 4bbl and HEI.. I can work on it on te sand bar without a diagnostic comp
Old Jan 26, 2014 | 03:22 PM
pro-tech's Avatar
Most of the intake companies make an intake for that set up...And to install a dist. is no big deal either...MSD, Mallory, even Mopar there all plug and play and easy to wire just follow the instuctions that come with them...
Old Jan 26, 2014 | 05:00 PM
Scat Rotating asm.
Voodoo Cam
Clean up and mild port your heads
Airgap intake
750cfm Holley
Great combo...You will like it...
Old Jan 26, 2014 | 08:53 PM
moe7404's Avatar
years ago i built a 360. i got tired if most mopar engines vibrating while running. so i had it balanced best $150. i ever spent.
69POLARA383
Oct 23, 2010 07:50 AM
sixfive407
Aug 31, 2010 02:19 PM
koondawg_74 roadrunner
Jul 3, 2009 10:49 PM
Brent1960
May 9, 2009 02:19 PM
dobaon22s
Nov 5, 2008 01:42 AM
