New ignition system
Old Sep 17, 2019 | 06:17 PM
SPAMBURGER's Avatar
New ignition system
Well it’s been a while but I’ve finally got the 440 back in the truck and running. I had to replace all the wiring due to it cracking and shorting out all over. While I was doing that I bought a Mallory 6al and unilite distributor. The distributor doesn’t have vacuum advance and I am wondering if anyone knows about where the timing should be? I haven’t really had time to play with it but so far I have it set at 14 deg initial and it seems to be running pretty good. Is there anything I should watch out for with this set up? The motor is bored .030 and I’m running CNC ported 516 heads with a 232/245 518 lift cam.
Old Sep 17, 2019 | 08:13 PM
Of all the 440s I've had with iron heads I haven't seen one that didn't want 38 degrees total. That said initial timing could be a little more maybe 16 degrees with the total all in by 2500 rpm. I would try a little more timing a/ idle and limit it to 38 total, you can always go back to 14.
Good luck
Tom
Old Sep 17, 2019 | 09:14 PM
SPAMBURGER's Avatar
Thanks for the info Tom, I’ll play with it a little more next week. I’m hoping to be driving it around before the snow falls here in Utah.
Old Sep 17, 2019 | 09:34 PM
You said a four letter word SNOW, your in a heap of trouble! Lol
That should be a fairly snoty 440 you have there, what gears and converter do you have?
Old Sep 18, 2019 | 06:13 AM
I have ran the HyFire stuff. Worked good for what i was using it for... I agree, looks and sounds like it mite take somemore timing...
Old Sep 18, 2019 | 09:06 AM
SPAMBURGER's Avatar
Right now it has a 3.23 open rear end and I'm not sure what converter it has but I have a 3.54 sure grip that I am in the middle of rebuilding for it.
Old Sep 18, 2019 | 05:29 PM
Get the right converter in it and it should be a ripper, haven't seen any pictures in a while how about putting a few up for us?
Thanks Tom
Old Sep 18, 2019 | 08:28 PM
SPAMBURGER's Avatar
I want to do something else with the wheels and tires but I’m still not sure what I want to do.
This is when I just dropped it in
Old Sep 18, 2019 | 09:39 PM
Looks great!👍
Old Sep 19, 2019 | 09:29 AM
SPAMBURGER's Avatar
This was just this morning, I still need to do the exhaust and I’m going to drop it 2”
Old Sep 19, 2019 | 08:53 PM
John Van's Avatar
My cuda has the same setup, msd 6al,unilite dist. Put in lighter advance springs in the unilite and it really woke it up.
Old Sep 19, 2019 | 10:37 PM
SPAMBURGER's Avatar
Thanks for the tip, I’ll check that out! Nice car by the way, I have always loved the cuda
Zenwren
13
Nov 30, 2018 04:55 PM
1975Powerwagon
Oct 23, 2015 01:38 PM
440 aspen
Dec 21, 2013 09:51 AM
garthed
Sep 5, 2013 05:58 PM
Gorts 5th
Dec 19, 2012 04:52 PM
