Oil pan gasket
Old Jul 5, 2013 | 05:43 AM
schizm12487's Avatar
Oil pan gasket
Hey, Everyone. I just wanted to ask before I open a can of worms. I need to replace my oil pan gasket (68 Fury 318). It looks like there is enough room to unbolt the pan and remove it without having to disassemble the front end or jack the engine up. Anyone know for sure if it is like that? Just wanted to be sure what I was getting into before I start.
Old Jul 5, 2013 | 07:14 AM
You may have to jack the motor up a tad bit.
Old Jul 5, 2013 | 12:22 PM
You will need to disconnect the tie rods and raise the engine up
Old Jul 5, 2013 | 02:04 PM
moe7404's Avatar
all so on some engines in the 60 you will have to rotate the crank to get the pan off. i dont like RTV. i use permatex #2 item# 80016. it does NOT slip around like RTV.
70roadrunner383
Nov 14, 2014 11:09 PM
TVLynn
Oct 11, 2013 01:36 PM
Mr. Belvedere II
Jun 21, 2012 08:50 AM
tahoeskier
Jun 18, 2011 06:59 PM
dzltd02
Oct 28, 2008 08:25 AM
